Re: [Mpi3-rma] MPI-3 UNIFIED model clarification
On 07/29/2013 10:58 PM, Underwood, Keith D wrote:
P1: Win_lock_all MPI_Recv(P0, flag) read a
Can you point to the line in there that tells the architecture that the read of A is not touched by MPI_Recv? Let's say the data movement for MPI_Recv is done by a NIC or done by another core. How can the microarchitecture tell the difference?
'flag' and 'a' are two different buffers, so presumably reordering MPI_RECV and 'read a' should be permitted. Are you saying that the architecture cannot track that these two are nonoverlapping buffers? Or are you saying that the "poll completion queue" equivalent for the network receive should already be doing a memory barrier for a correct network stack anyway? If it's the latter, then let's consider the following new example: P0: Barrier Win_lock_all(win1) Put(a, P1) Flush flag = 1; Put(flag, P1) P1: flag = 0; Barrier Win_lock_all while (flag); read a Remember MPI-3's nasty semantics of single-byte flags turning to non-zero and staying there :-). -- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
