Re: [mpiwg-rma] Ticket 434 - Re: Added 4 extra tickets to the RMA wiki
Rajeev, you are right, this missing rule exist in the definitions of MPI_Win_fence (MPI-3.0 page 440 last word - page 441 line 35) and for MPI_Win_start on page 442 lines 30-31: "RMA accesses to each target window will be delayed, if necessary, until the target process executed the matching call to MPI_WIN_POST." It is fine that the standard is complete, but it is still not good that the semantic rules on page 454 are incomplete. What is your advice on how to proceed with this significantly smaller problem. Rolf ----- Original Message -----
From: "Rajeev Thakur" <[email protected]> To: "MPI WG Remote Memory Access working group" <[email protected]> Cc: "Bill Gropp" <[email protected]>, "Marc Snir" <[email protected]>, "Rajeev Thakur" <[email protected]> Sent: Monday, June 30, 2014 5:01:52 PM Subject: Re: [mpiwg-rma] Ticket 434 - Re: Added 4 extra tickets to the RMA wiki
but I do not see any rule that guarantees that the MPI_Win_fence in Process 0 defers the MPI_Get until Process 1 has put the value into the public copy of Window_var.
Rolf, See the definition of Win_fence on pg 441
"RMA operations on win started by a process after the fence call returns will access their target 34 window only after MPI_WIN_FENCE has been called by the target process."
and Rule 5 on pg 454
• An update of a location in a private window copy in process memory becomes visible in the public window copy at latest when an ensuing call to MPI_WIN_POST, MPI_WIN_FENCE, MPI_WIN_UNLOCK, MPI_WIN_UNLOCK_ALL, or MPI_WIN_SYNC is executed on that window by the window owner.
Rajeev
On Jun 30, 2014, at 9:27 AM, Rolf Rabenseifner <[email protected]> wrote:
You are right with all what you said, but with this, an implementation is also correct when Exa 11.2 does not work. Here the details:
The problem is, as we three saw, that you have still a correct MPI implementation, that does not fulfill Example 11.2 on page 424, but that fulfills all requirements of the current MPI-3.0 (and old MPI-2.0) specification. In other words, MPI-3.0 RMA semantics is not complete.
Example 1
Process 0 Process 1
Loop Loop Window_var = some value MPI_Win_fence MPI_Win_fence MPI_Get(buf,..rank=1) MPI_Win_fence MPI_Win_fence print buf End_loop End_loop
MPI-3.0 page 454 rule 5 guarantees in Process 1 that after MPI_Win_fence, the Window_var value is in the public copy but I do not see any rule that guarantees that the MPI_Win_fence in Process 0 defers the MPI_Get until Process 1 has put the value into the public copy of Window_var.
There is only the rule that MPI_FENCE has to act as the corresponding PSCW commands.
Same with PSCW - Example 2
Process 0 Process 1
Loop Loop Window_var = some value MPI_Win_post MPI_Win_start MPI_Get(buf,..rank=1) MPI_Win_complete MPI_Win_wait print buf End_loop End_loop
Same problem as above. MPI_Get is allowed to Access the value in Window_var that was stored there before Window_var = some value MPI_Win_post took place.
The new rule would forbid this unexpected behavior of an MPI library:
7. An RMA operation issued at the origin after MPI_WIN_START or MPI_WIN_FENCE to a specific target, accesses the public window copy at the target that is available after the matching MPI_WIN_POST or MPI_WIN_FENCE at the target.
This rule would not forbid implementations with delayed accesses. It only guarantees that "some value" in process 1 will be printed in process 0, Independent of the internals of the MPI library.
Rolf
From: "Pavan Balaji" <[email protected]> To: "MPI WG Remote Memory Access working group" <[email protected]> Cc: "Bill Gropp" <[email protected]>, "Marc Snir" <[email protected]> Sent: Monday, June 30, 2014 4:13:58 PM Subject: Re: [mpiwg-rma] Ticket 434 - Re: Added 4 extra tickets to the RMA wiki
Rajeev,
We understand the “may” part and that’s the entire point of the ticket. That is, the user cannot assume that it’ll block. Hence either the examples are wrong or the wording is wrong. We believe the wording is incorrect.
— Pavan
On Jun 30, 2014, at 8:58 AM, Rajeev Thakur <[email protected]> wrote:
The ticket's premise is wrong in my opinion :-).
First of all the sentence "For post-start-complete-wait, there is no specified requirement that the post and start calls need to synchronize." is not right.
pg 442, ln 31-33: "MPI_WIN_START is allowed to block until the corresponding MPI_WIN_POST calls are executed, but is not required to."
When the standard says the first fence "may" not be a barrier or the above where start "may" not block, it means that if the implementation is able to provide the right fence or pscw semantics without a barrier or block, it may. If it cannot, then it should barrier or block or do something.
An example of where the "may" case works is where the implementation defers all RMA operations to the "second" fence or to the wait-complete. In that case, it is free not to barrier in the first fence or wait for the post.
Rajeev
On Jun 30, 2014, at 5:39 AM, Rolf Rabenseifner <[email protected]> wrote:
Marc, Bill, and Rajeev,
Marc, as far as I remember, you are the author of the 6 rules on one-sided semantics on MPI-3.0 page 453 line 39 through page 454 line 21 (in MPI-2.0 the rules were on page 138).
At ISC 2014, Pavan Balaji, Hubert Ritzdorf and I met to discuss the unclear RMA synchronization for shared memory, but we had to start with a problem in RMA semantics that exists since MPI-2.0.
The outcome was https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/434
Marc as original author, Bill and Rajeev as chapter chairs, please can you check whether we are right with this ticket:
- that the gap between the expected behavior and the current semantic rules really exists, and - that our solution is correct, - and hopefully that it is a good way of filling the gap.
Best regards Rolf
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
participants (1)
Rolf Rabenseifner
