The argument was that we don't want to add a collective function in passive target RMA, and should instead use Fence. Specifically, since all-lock-all forces shared lock (it doesn't make sense for exclusive lock), one would give mode-no-check, and the MPI implementation can optimize the lock functionality to a no-op anyway. However, if there was a proposal for collective flush or unlock, I'd be supportive of that. The reason being that I can decide dynamically if I want to do a single flush-all or a collective flush-all based on my program semantics, instead of having to decide that at epoch opening time. -- Pavan Sent from my iPhone
On Feb 3, 2015, at 11:39 AM, Jeff Hammond <[email protected]> wrote:
I know we discussed a collective lock_all function at some point. Why didn't we do it?
In every single MPI-3 RMA program I have every written, I do this:
... MPI_Win_allocate(..,&win); MPI_Win_lock_all(win); ...
When everyone calls MPI_Win_lock_all, the traffic pattern is consistent with MPI_Alltoall. On the other hand, a collective invocation would allow for setting the LOCK_ALL state locally and merely achieving consensus on this effect, which means MPI_Allreduce traffic.
In terms of the performance difference one will see with these implementations, here is some data for Blue Gene/Q on 48 racks (49152 nodes with 16 ppn):
MPI_Allreduce 1 integers in 0.000018 seconds MPI_Alltoall 786432 integers in 1.52 seconds <- the count here means one integer per process
For those not keeping score at home, that's a performance difference of approximately 36314x. And this is quite generous to MPI_Win_lock_all, because not only is it not collective and therefore MPI cannot possibly coalesce or otherwise optimize the packet storm, but instead of a simple data copy, an MPICH:Ch3-derived implementation is going to slam the target with nproc active message requests, leading to an enormously pile up at scale.
Here is more data (approximate, due to lack of repetition in measurement, although the times do not include connection overhead, etc.):
Cray XC30 np=8192 MPI_Allreduce 1 integers in 0.000033 seconds MPI_Alltoall 8192 integers in 0.0051 seconds
np=8192 (1024x8) MPI_Allreduce 2 integers in 0.000015 seconds MPI_Alltoall 8192 integers in 0.0034 seconds
In the limit of small np, the differences are less noticeable, as one might expect.
Unless there's a compelling reason not to fix this, I'll propose either MPI_Win_all_lock_all. I have no use case for locking a subset of the window group collectively, so I do not intend to propose this.
Jeff
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
participants (1)
Balaji, Pavan
