Re: [Mpi3-rma] Dynamic windows example
Hi Torsten, Thanks for your comments!
In the process of trying to gain a deeper understanding of the dynamic windows proposal I wrote a small distributed linked list example. I've attached the code in case this may be helpful for others. Please feel free to dissect, modify, post questions, complaints, etc.
Thanks for sharing your code. It's a good example for a dynamic window and the use of flush. Did you consider using MPI_Compare_and_swap() for the pointer chase? This would require another MPI_Get() in case you didn't get the tail but would allow for much more concurrency than the lock exclusive version (each lock/unlock incurs one roundtrip latency).
I had initially done a CAS on the rank followed by a put on the displacement, but the code was a bit messy so I went for the simpler Get-Flush-Put option. When chasing the tail, I ended up having to poll on the second component of the pointer in case I saw the result of the CAS, but not yet the result of the put. Looking at it again though, it seems like you ought to be able to just define the pointer with the same type for both elements: typedef struct { MPI_Aint proc, disp; } llist_ptr_t; and accomplish this is one CAS operation. (You might have to do a hack like set the value of nil.proc to 0 since MPI_Aint is unsigned and increment all process ids so that proc has a proper nil value in case two CAS operations overlap.) If you did this with shared locks, it seems like you will still have the polling problem since CAS is element-wise atomic. If you use exclusive locks you won't get as much concurrency, but it's a single one-sided CAS operation instead of Get-Flush-Put.
Using MPI_BYTE in the broadcast is also not working in heterogeneous environments (where you should also compare the sizes of MPI_Aint).
Will dynamic windows be usable on such systems if processes don't agree on the size of MPI_Aint? Best, ~Jim.
participants (1)
James Dinan
