Re: [Mpi3-rma] mpi3-rma post from [email protected] requires approval
I tend to agree that (2) is what is critical, but both (1) & (2) may be important. The problem with not having (1) is that it gets significantly more expensive to figure out when a message has been delivered. <shrug> that may be ok, but may be a pain. Seems like (2) is the most useful to support. As far as (1), is probably not safe to ever legally allow a user poll on a last byte to check for message being delivered; it also is a heavy weight process to give this guarantee when a system doesn't. Thanks,Vinod.
Thanks for listing these. If we are voting for this, my vote would be to have (2) and toss out (1) and (3).
-- Pavan
On 06/05/2010 02:40 PM, Underwood, Keith D wrote:
I was only giving an example of how tightly ordering COULD be defined. Ordering options include:
1) Ordering within a given replace: is the first byte guaranteed to get there before the last? 2) Ordering between replaces to a given location: but, what if two replaces are overlapping? 3) Ordering among all replaces to a given node
Two sided gives you something weird, in that it orders the matching of the message headers and not the end of messages or data within the messages.
Keith
-----Original Message----- From: Pavan Balaji [mailto:[email protected]] Sent: Saturday, June 05, 2010 3:30 PM To: Underwood, Keith D Cc: MPI 3.0 Remote Memory Access working group; [email protected] Subject: Re: [Mpi3-rma] mpi3-rma post from [email protected] requires approval
I see. My definition of ordering was a little bit different from yours.
My definition was -- if I do two accumulates with replace on the same location, I'm guaranteed to have the second value in the location. It didn't have any definition of ordering to two different locations.
So, I think we need to come to a consensus first on what the actual definition of ordering is.
-- Pavan
On 06/05/2010 02:22 PM, Underwood, Keith D wrote:
We would need to think about whether we have to have the whole message ordered or ordered on a per target address basis. Atomicity and ordering go hand-in-hand; if there's no atomicity, ordering doesn't make sense. Since we have basic datatype atomicity for accumulate/get_accumulate, ordering would make sense at that granularity as well.
If someone wants to propose full-message atomicity, then we can consider ordering at that granularity too. But till then, whole message ordering is an overkill. Well, they aren't orthogonal, but they aren't quite that tightly linked. A user that knew that two messages were not going to overlap might want to use a full message ordering from a single node for completion detection. E.g. an MPI_Accumulate() with "replace" to one buffer and then an MPI_Accumulate() to another buffer to increment a variable and use the full message ordering to be able to use the latter for completion without the expense of a flush() between the messages. So, it has value and a usage scenario. I just don't know if we want to go that far or not. Keith -- Pavan Balaji http://www.mcs.anl.gov/~balaji
_______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
participants (1)
Vinod tipparaju
