Re: [Mpi3-rma] Next RMA Telecon
On 12/26/2011 08:48 PM, Torsten Hoefler wrote:
Why does:
win_fence() if(rank == 0) { initialize_window(); MPI_Barrier(); } else MPI_Barrier(); win_fence() // all procs read written data here
not work for Ron's use-case? Are you talking about another use-case?
I see. I thought you were referring to using point-to-point/collectives alone without any RMA calls. Also, the case I had in mind was using lock/unlock. If it is valid for the user to do a for loop of Win_lock(exclusive), I'm not sure how we are taking away the MPI implementation burden by not allowing Win_lock_all(exclusive). More importantly -- even if we want to not allow exclusive locks in WIN_LOCK_ALL, I would suggest retaining the lock_type parameter and say that the behavior of EXCLUSIVE locks is undefined, so that it's future proof in case we want to add it later. Also, implementations that want to provide it can do so without random hacks or new API functions. Btw, I assume the following would be valid? Win_allocate_shared(shared_mem, &shared_win); Win_create(shared_mem, &remote_win); /* overlapping window */ P0: Win_lock_all(SHARED, &shared_win); Recv(P1); Barrier(); ALL_OTHER_PROCESSES_SHARING_SHARED_WIN: Barrier(); REMOTE_PROCESS: Win_lock(EXCLUSIVE, P0, remote_win); Put(P0, remote_win); Win_unlock(P0); Send(P0); The idea is that a process gets a lock on a shared memory region and uses it for remote RMA communication. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
