Re: [Mpi3-rma] non-contiguous support in RMA & one-sided pack/unpack (?)
"else" condition is non-trivial when
one considers the latency of the BlueGene/P interconnect, the memory latency, the clock rate and the absence of dynamic communication threads. Forgive me for being specific to one machine, but it is the benchmark data I have obtained that inspires me to comment on these issues You have a valid point, but, as you already note, BG is an exception. It is a "slowed down" exception. In most cases, latency associated with branching will have to continue to be insignificant (by 2 orders of magnitude) WRT to network latency. Hence what needs to be done for non-contiguous data WRT and in the network is more important than a mere branch. What the network does or doesn't do to support non-contiguous data transfers is critical. The input/guidance forum gives hence is more important when taken during the network design -- many things may be fixed in an implementations but one cannot fix what a network lack here.
Basically, you believe having two calls instead of one will help because you believe you can help the implementation by giving hints on what you need from this particular RMA transfer. I added attributes for a similar reason. Usages are many, we cannot have an interface for each usage. We can however use attributes to give hints/orders that may help implementations utilize networks better or know when to give up. We can also support features such as Binding (discussed in the last meeting) to help reduce latency. Thanks,Vinod.
Date: Wed, 16 Sep 2009 09:28:31 -0500 From: [email protected] To: [email protected] Subject: Re: [Mpi3-rma] non-contiguous support in RMA & one-sided pack/unpack (?)
1) MPI is implemented as a library. There is no connection between the analysis the compiler can do and the MPI implementation so what can be "known" by the compiler cannot be communicated to the implementation.
Yes, I am well aware of this. What I mean is that I, the programmer, can choose to use in my source code the function or function arguments which invoke the fastest correct call, thus preventing MPI from proceeding through all the logic necessary to decipher the most general case.
For example, if "xfer" contained a flag just for contiguous/non-contiguous, I could do the following in my code:
====================================== /* get row */ ( invoke xfer_get with contig flag set and using the simple datatype for a contiguous vector of floats)
/* get column */ ( invoke xfer_get with noncontig flag set and using derived datatype for the column vector of a matrix of floats) ======================================
knowing that MPI can implement "xfer" like this:
====================================== xfer_get ( ... ){ if (contig){ low_level_comm_api_get(...) } else { process_datatype(...) /* figure out how many contiguous segments are in this */ #ifdef (FAST_INJECTION_RATE) (for all contig segments in datatype){ low_level_comm_api_get(...,datatype,...) } #elseif (SLOW_INJECTION_RATE) active_message(invoke_remote_pack(datatype,packed_buffer)) low_level_comm_api_get(...,packed_buffer,...) local_unpack(packed_buffer,datatype) #endif } ======================================
If you look at ARMCI or the MPI-2 one-sided implementation over DCMF, the overhead associated with the "else" condition is non-trivial when one considers the latency of the BlueGene/P interconnect, the memory latency, the clock rate and the absence of dynamic communication threads. Forgive me for being specific to one machine, but it is the benchmark data I have obtained that inspires me to comment on these issues.
On machines with capped message injection rates, implementing the "else" condition might be best done in a completely different manner with one-sided packing, which is why I brought that up in the first place. Of course, the overhead of packing is large and thus should be reserved exclusively for the case where hardware prefers it, and then only for "xfer" calls where it is absolutely necessary, otherwise it should be ignored completely.
2) There is no requirement in MPI that all tasks of an application run the same executable so even if one piece of source code that will be used in an application is free of complex datatypes, only the human being who knows if other pieces of code will be used by some tasks can make the judgement that there will be no calls with complex datatypes by any participating task.
While this may be true for MPI ("no requirement that all tasks of an application run the same executable"), it may not be true for all systems on which MPI is to be run. Hence, I do not think this is a useful solution.
It is exactly my point that the human knows which calls require complex datatypes and should be able to make calls to "xfer" in light of this knowledge. Currently the "xfer" API does not support bypassing complex datatypes and it is my contention that, in some cases, doing so will improve performance markedly.
Best,
Jeff
-- Jeff Hammond Argonne Leadership Computing Facility [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond http://home.uchicago.edu/~jhammond/ _______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
participants (1)
Vinod tipparaju
