Re: [Mpi3-rma] RMA proposal 1 update
Just because you may need access to the entire array doesn't mean that you will access the entire array in every interval between calls to flushall(). The choices other than flush()/flushall() are not pretty for completion, though. Actually, a perfect example of when I doubt that allflushall() is going to be efficient this way is HPCC RandomAccess on a 1M rank system. In an interval, you may need to access any node, but you are going to access (at most) 1024 other nodes. Now, if you call allflushall(), which is the obvious thing to do, it is seems like it would be slower than calling flushall()+barrier(). After all, the source knows that it only needs to check the status at 1024 ranks (worst case) rather than doing a 4MB allreduce(). Any chance you could do a back-of-the-envelope calculation as to where the cross-over is? BTW, if you could get hardware to expose remote completion information to you, this point would be moot ;-) Keith
-----Original Message----- From: [email protected] [mailto:mpi3-rma- [email protected]] On Behalf Of Douglas Miller Sent: Tuesday, May 18, 2010 10:04 AM To: MPI 3.0 Remote Memory Access working group Subject: Re: [Mpi3-rma] RMA proposal 1 update
If the fence epoch involved 1 million ranks all doing origin and/or target operations, then the allreduce is likely to be efficient (unless a reduce_scatter_block sort of thing exists). If there are only 10 participants doing RMAs in a 1 million participant fence epoch, one would have to question why use fence for the synchronization - or why use a 1 million member communicator to create the window. That does not seem like an optimal communication pattern.
_______________________________________________ Douglas Miller BlueGene Messaging Development IBM Corp., Rochester, MN USA Bldg 030-2 A410 [email protected] Douglas Miller/Rochester/IBM
"Underwood, Keith D" <keith.d.underwoo To [email protected]> "MPI 3.0 Remote Memory Access Sent by: working group" mpi3-rma-bounces@ <[email protected]> lists.mpi-forum.o cc rg
Subject Re: [Mpi3-rma] RMA proposal 1 05/18/2010 10:51 update AM
Please respond to "MPI 3.0 Remote Memory Access working group" <[email protected] pi-forum.org>
Ah, so you allreduce(MPI_SUM, 1 million element integer vector == 4MB)? Then you know how many things you should have received and when you have received all of those you can enter a barrier?
Ok, now I am curious about a couple of other things:
1) Can you separate RMA operations from other operations in your counts? E.g. one-sided, non-blocking collectives, etc. 2) is an allreduce of a big vector really more efficient in the general case? I can see how it might (maybe) be better for HPCC RandomAccess types of things (i.e. if you did RandomAccess as Accumulate operations), but I am dubious about whether it helps for anything else.
I'm just wanting to make sure that the optimization potential here is real...
Thanks, Keith
-----Original Message----- From: [email protected] [mailto:mpi3-rma- [email protected]] On Behalf Of Douglas Miller Sent: Tuesday, May 18, 2010 9:44 AM To: MPI 3.0 Remote Memory Access working group Subject: Re: [Mpi3-rma] RMA proposal 1 update
If each origin (in a fence epoch) keeps track of the count(s) of RMA operations to each of its targets, then an allreduce of those arrays will tell each target how many operations were done to itself and can be used to determine completion.
Subject Re: [Mpi3-rma] RMA proposal 1 05/18/2010 10:23 update AM
Sorry, but you lost me at “we could just do an allreduce to look at counts”. Could you go into a bit more detail? If you have received counts from all ranks at all ranks (um, that doesn’t seem scalable), then it would seem that an allfenceall() would require an Alltoall() to figure out if everybody was safe. I don’t see how an allreduce would do the job. But, I’ll admit that I don’t know really DCMF or BG network interface architecture or… So, I could just be missing something here.
Thanks, Keith
From: [email protected] [ mailto:[email protected]] On Behalf Of Brian Smith Sent: Tuesday, May 18, 2010 4:57 AM To: MPI 3.0 Remote Memory Access working group Cc: MPI 3.0 Remote Memory Access working group; [email protected] Subject: Re: [Mpi3-rma] RMA proposal 1 update
Sorry for the late response.... On BGP, DCMF Put/Get doesn't do any accounting and DCMF doesn't actually have a fence operation. There is no hardware to determine when a put/get has completed either. We need to send a get along the same (deterministically routed) path to "flush" any messages out to claim we are synchronized.
When we implemented ARMCI, we introduced accounting in our "glue" on top of DCMF because of the ARMCI_Fence() operation. There are similar concerns in the MPI one-sided "glue".
Going forward, we need to figure out how we'd implement the new MPI RMA operations and determine if there would be accounting required. If there would be (and I'm thinking there would), then an allfenceall in MPI would be easy enough to do and would provide a significant benefit on BG. We could just do an allreduce to look at counts. If the standard procedure is fenceall()+barrier(), I could do that much better as an allfenceall call.
On platforms that have some sort of native accounting, this allfenceall would only be the overhead of a barrier. So I think an allfenceall has significant value to the middleware more than DCMF and therefore would strongly encourage it in MPI, especially given the use-cases we heard from Jeff H. at the forum meeting.
This scenario is the same in our next super-secret product offering everyone knows about but I don't know if *I* can mention.
Brian Smith ([email protected]) BlueGene MPI Development/ Communications Team Lead IBM Rochester Phone: 507 253 4717
To: "MPI 3.0 Remote Memory Access working group" <[email protected]>
Date: 05/16/2010 09:33 PM
Subject Re: [Mpi3-rma] RMA proposal 1 update :
Sent [email protected] by:
Before doing that, can someone sketch out the platform/API and the implementation that makes that more efficient? There is no gain for Portals (3 or 4). There is no gain for anything that supports Cray SHMEM reasonably well (shmem_quiet() is approximately the same semantics as MPI_flush_all). Hrm, you can probably say the same thing about anything that supports UPC well - a strict access is basically a MPI_flush_all(); MPI_Put(); MPI_flush_all();... Also, I thought somebody said that IB gave you a notification of remote completion...
The question then turns to the "other networks". If you can't figure out remote completion, then the collective is going to be pretty heavy, right?
Keith
-----Original Message----- From: [email protected] [mailto:mpi3-rma- [email protected]] On Behalf Of Jeff Hammond Sent: Sunday, May 16, 2010 7:27 PM To: MPI 3.0 Remote Memory Access working group Subject: Re: [Mpi3-rma] RMA proposal 1 update
Tortsten,
There seemed to be decent agreement on adding MPI_Win_all_flush_all (equivalent to MPI_Win_flush_all called from every rank in the communicator associated with the window) since this function can be implemented far more efficiently as a collective than the equivalent point-wise function calls.
Is there a problem with adding this to your proposal?
Jeff
On Sun, May 16, 2010 at 12:48 AM, Torsten Hoefler <[email protected]> wrote:
Hello all,
After the discussions at the last Forum I updated the group's first proposal.
The proposal (one-side-2.pdf) is attached to the wiki page https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/RmaWikiPage
The changes with regards to the last version are:
1) added MPI_NOOP to MPI_Get_accumulate and MPI_Accumulate_get
2) (re)added MPI_Win_flush and MPI_Win_flush_all to passive target mode
Some remarks:
1) We didn't straw-vote on MPI_Accumulate_get, so this function might go. The removal would be very clean.
2) Should we allow MPI_NOOP in MPI_Accumulate (this does not make sense and is incorrect in my current proposal)
3) Should we allow MPI_REPLACE in MPI_Get_accumulate/MPI_Accumulate_get? (this would make sense and is allowed in the current proposal but we didn't talk about it in the group)
All the Best, Torsten
-- bash$ :(){ :|:&};: --------------------- http://www.unixer.de/ - -- -- Torsten Hoefler | Research Associate Blue Waters Directorate | University of Illinois 1205 W Clark Street | Urbana, IL, 61801 NCSA Building | +01 (217) 244-7736 _______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
-- Jeff Hammond Argonne Leadership Computing Facility [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond
_______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma _______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
participants (1)
Underwood, Keith D
