Re: [mpiwg-rma] same_op_no_op
I believe we use the term "accumulate functions" to describe MPI_ACCUMULATE, MPI_GET_ACCUMULATE, MPI_FETCH_AND_OP and MPI_COMPARE_AND_SWAP and they are considered to be "the same" in some sense. If MPI_COMPARE_AND_SWAP is not interoperable with MPI_GET_ACCUMULATE (which is a superset of MPI_ACCUMULATE and MPI_FETCH_AND_OP), then SHMEM is impossible. I don't believe we intended to do this. I thought the whole point of Keith and Brian torturing the Forum with argument count, ordering-by-default, etc. was to make SHMEM over MPI-3 possible... :-) Jeff On Fri, Mar 14, 2014 at 2:37 PM, Jim Dinan <[email protected]> wrote:
Does same_op_no_op_replace allow MPI_NO_OP, MPI_REPLACE, MPI_SUM, *and* MPI_Compare_and_swap (i.e. to support shmem_*_cswap)? I don't recall if CAS is semantically a different op, or if it's considered to be a "replace". I had thought it was considered to be a different op.
On Fri, Mar 14, 2014 at 10:11 AM, Jeff Hammond <[email protected]> wrote:
In that case impls can add new info key for same_op_no_op_replace_hardware or something.
SHMEM only needs same_op_no_op_replace as default but UPC appears to need SUM and XOR to be permitted at the same time to be efficient at the UPC runtime level.
Jeff
Sent from my iPhone
On Mar 14, 2014, at 8:37 AM, "Underwood, Keith D" <[email protected]> wrote:
The problem here is that some existing hardware supports some atomic operations. Multiply is frequently not on that list. Doing an atomic add on a non-coherent NIC and a multiply somewhere else can be challenging to make correct, much less atomic. Now, if "all bets are off" in the definition of not atomic (i.e. any interleaving of the two implied load-op-store sequencings is legal), then I would argue that the description you attribute to 2.2 is the better one.
-----Original Message----- From: mpiwg-rma [mailto:[email protected]] On Behalf Of Balaji, Pavan Sent: Thursday, March 13, 2014 1:02 PM To: MPI WG Remote Memory Access working group Subject: Re: [mpiwg-rma] same_op_no_op
MPI-2.2 says that accumulate with different ops are not atomic.
MPI-3 says that accumulate with different ops are not allowed (since same_op_no_op is default).
I think we screwed that up?
- Pavan
On Mar 13, 2014, at 11:48 AM, Jeff Hammond <[email protected]> wrote:
It is extremely difficult to see that this is what the MPI-3 standard says.
First we have this:
"The outcome of concurrent accumulate operations to the same location with the same predefined datatype is as if the accumulates were done at that location in some serial order. Additional restrictions on the operation apply; see the info key accumulate_ops in Section 11.2.1. Concurrent accumulate operations with different origin and target pairs are not ordered. Thus, there is no guarantee that the entire call to an accumulate operation is executed atomically. The effect of this lack of atomicity is limited: The previous correctness conditions imply that a location updated by a call to an accumulate operation cannot be accessed by a load or an RMA call other than accumulate until the accumulate operation has completed (at the target). Different interleavings can lead to different results only to the extent that computer arithmetics are not truly associative or commutative. The outcome of accumulate operations with overlapping types of different sizes or target displacements is undefined." [11.7.1 Atomicity]
Then we have this:
"accumulate_ops - if set to same_op, the implementation will assume that all concurrent accumulate calls to the same target address will use the same operation. If set to same_op_no_op, then the implementation will assume that all concurrent accumulate calls to the same target address will use the same operation or MPI_NO_OP. This can eliminate the need to protect access for certain operation types where the hardware can guarantee atomicity. The default is same_op_no_op." [11.2.1 Window Creation]
I was not aware that the definition of info keys was normative, given that implementations are free to ignore them. Even if info key text is normative, one has to infer from the fact that same_op_no_op is the default info behavior - and thus RMA semantic - that accumulate atomicity is restricted to the case where one uses the same op or noop but not replace.
The MPI-2.2 spec is unambiguous because it explicitly requires the same operation in 11.7.1 Atomicity. This text was removed in MPI-3.0 in favor of the info key text.
Best,
Jeff
On Tue, Mar 11, 2014 at 12:04 AM, Balaji, Pavan <[email protected]> wrote:
MPI-2 defines atomicity only for the same operation, not any operation for MPI_ACCUMULATE.
- Pavan
On Mar 10, 2014, at 11:22 PM, Jeff Hammond <[email protected]> wrote:
So MPI-2 denied compatibility between replace and not-replace?
Jeff
Sent from my iPhone
On Mar 11, 2014, at 12:06 AM, "Balaji, Pavan" <[email protected]> wrote:
It doesn't break backward compatibility. The info argument is still useful when you don't want to use replace. I don't see anything wrong with it.
On Mar 10, 2014, at 11:01 PM, Jeff Hammond <[email protected]> wrote:
Does this or does this not break BW compatibility w.r.t. MPI-2.2 and did we do it intentionally? Unless we did so intentionally and explicitly, I will argue that the WG screwed up and the info key+val is invalid.
Jeff
On Mon, Mar 10, 2014 at 11:03 PM, Balaji, Pavan <[email protected]> wrote:
If a hardware can implement MPI_SUM, it should be able to implement MPI_SUM with 0 as well.
But that's not a generic solution.
Jeff: at some point you were planning to bring in a ticket which does more combinations of operations than just same_op and no_op. Maybe it's worthwhile bringing that up again?
- Pavan
On Mar 10, 2014, at 9:26 PM, Jim Dinan <[email protected]> wrote:
Maybe there's a loophole that I'm forgetting?
On Mon, Mar 10, 2014 at 9:43 PM, Jeff Hammond <[email protected]> wrote: How the hell can I do GA or SHMEM then? Roll my own mutexes and commit perf-suicide?
Jeff
Sent from my iPhone
On Mar 10, 2014, at 8:32 PM, Jim Dinan <[email protected]> wrote:
You can't use replace and sum concurrently at a given target address.
~Jim.
On Mon, Mar 10, 2014 at 4:30 PM, Jeff Hammond <[email protected]> wrote: Given the following, how do I use MPI_NO_OP, MPI_REPLACE and MPI_SUM in accumulate/atomic operations in a standard- compliant way?
We discuss this before and the resolution was not satisfying to me.
Jeff
-- Jeff Hammond [email protected] _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
participants (1)
Jeff Hammond
