Re: [mpiwg-rma] Inconsistency of MPI_WIN_FENCE semantic
As per Rajeev, the standard is asking implementations to either defer all PUT/GET operations (in which case WIN_FENCE is not a barrier) or do eager RMA operations and force MPI_WIN_FENCE to be a barrier. That’s an implementation choice. The user cannot assume that it’ll always be the latter. — Pavan On Feb 25, 2014, at 11:23 PM, Zhao, Xin <[email protected]> wrote:
I still think that on P441 "RMA operations on win started by a process after the fence call returns will access their target window only after MPI_WIN_FENCE has been called by the target process" should add "when MPI_MODE_NOPRECEDE is not given". In this example Put is possible to access target memory before target calls Fence(NOPRECEDE), but user is not aware of that according to the Standard.
Xin
________________________________________ From: mpiwg-rma [[email protected]] on behalf of Rajeev Thakur [[email protected]] Sent: Tuesday, February 25, 2014 11:09 PM To: MPI WG Remote Memory Access working group Subject: Re: [mpiwg-rma] Inconsistency of MPI_WIN_FENCE semantic
It means to say that in the example below, the second fence (which does not end any epoch) does not necessarily act as a barrier. The NOPRECEDE makes it very clear (and hence the "in particular a call with assert=NOPRECEDE") that no RMA calls were issued prior to that fence.
Fence x=1 Fence(NOPRECEDE) Put Fence
Note that a fence "completes an RMA access epoch if it was preceded by another fence call and the local process issued RMA communication calls on win between these two calls. The call completes an RMA exposure epoch if it was preceded by another fence call and the local window was the target of RMA accesses between these two calls."
So the second fence does not complete any epoch, which the user has made even more clear with the assert, and so it need not be a barrier.
On Feb 25, 2014, at 10:58 PM, "Balaji, Pavan" <[email protected]> wrote:
Then the following sentence in the standard is weird:
"a call to MPI_WIN_FENCE that is known not to end any epoch (in particular a call with assert equal to MPI_MODE_NOPRECEDE) does not necessarily act as a barrier”
Why this special treatment for NOPRECEDE as no WIN_FENCE has barrier semantics?
— Pavan
On Feb 25, 2014, at 10:54 PM, Rajeev Thakur <[email protected]> wrote:
Agreed that the handshake can't be done in the RMA operation.
If you choose to implement fence eagerly, i.e., perform RMA ops as they are called, the first fence will have to be a barrier.
But if you choose to implement the deferred fence, the first fence and all RMA ops can be deferred until the fence that completes the epoch.
On Feb 25, 2014, at 10:46 PM, "Zhao, Xin" <[email protected]> wrote:
I agree with this. If the handshake is done in the first RMA operation after the fence, then that operation becomes blocking. In Standard P418 it says all communication calls are non-blocking.
Xin ________________________________________ From: mpiwg-rma [[email protected]] on behalf of Balaji, Pavan [[email protected]] Sent: Tuesday, February 25, 2014 9:38 PM To: MPI WG Remote Memory Access working group Subject: Re: [mpiwg-rma] Inconsistency of MPI_WIN_FENCE semantic
In practice, it’ll need to have barrier semantics. Otherwise, PUT will need to be a two-sided operation to ensure that it’s not issued before the other process calls MPI_WIN_FENCE.
— Pavan
On Feb 25, 2014, at 9:21 PM, Rajeev Thakur <[email protected]> wrote:
(1) On P440-P441 it say that "RMA operations on win started by a process after the fence call returns will access their target window only after MPI_WIN_FENCE has been called by the target process". This requires MPI_WIN_FENCE that starts an epoch to act as an barrier.
It only says "RMA operations on win started by a process after the fence call returns will access their target window only after MPI_WIN_FENCE has been called by the target process". NOT "This requires MPI_WIN_FENCE that starts an epoch to act as an barrier."
Why does the fence have to act as a barrier. The handshake could be done when first RMA operation is called after the fence.
Rajeev
On Feb 25, 2014, at 8:41 PM, "Zhao, Xin" <[email protected]> wrote:
Hi all,
There is an inconsistency of MPI_WIN_FENCE semantic in MPI 3.0 Standard that makes me confused:
(2) However, (1) contradict with the word at end of P441: "a call to MPI_WIN_FENCE that is known not to end any epoch (in particular a call with assert equal to MPI_MODE_NOPRECEDE) does not necessarily act as a barrier".
Should the word of (1) add: "when MPI_MODE_NOPRECEDE is not given"?
Xin
_______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
_______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma _______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
participants (1)
Balaji, Pavan
