Re: [mpiwg-rma] MPI_Win_create on unmapped memory?
On Wed, Jan 3, 2018 at 1:07 AM, Thomas Jahns <[email protected]> wrote:
On 01/02/18 20:52, Jeff Hammond wrote:
If a user passes a (base,size) pair that corresponds to a range of
addresses that are not allocated and/or mapped, is that a correct MPI program?
Such a thing wouldn't be a valid object pointer in C/C++ or a variable in
Fortran, i.e. both languages prohibit this. Which of the following MPI_Win_create calls are not using a valid object pointer according to ISO C and/or C++? char a = '\0'; int main() { .. char * x = malloc(1); MPI_Win_create(x,1000,1,MPI_INFO_NULL,MPI_COMM_WORLD,&win); ... MPI_Win_create(&a,1000,1,MPI_INFO_NULL,MPI_COMM_WORLD,&win); .. foo(); // compiler cannot prove this function does not call // mmap(0x10000, 1, PROT_READ|PROT_WRITE, MAP_FIXED|MAP_ANONYMOUS, -1, 4096); .. MPI_Win_create(0x10000,1000,1,MPI_INFO_NULL,MPI_COMM_WORLD,&win); .. }
The only text I can find that implies that buffers passed to MPI_Win_create have to be allocated is the following, assuming that one interprets "existing memory" this way.
"Each process specifies a window of existing memory that it exposes to RMA accesses by the processes in the group of comm." (MPI 3.1 11.2.1)
Since MPI is a library standard I would still expect all the guarantees of the language standards involved to hold and the above to only be an additional clarification?
It's only a clarification. However, I don't think it's a good idea for the MPI standard to punt this off on ISO C, because not every implementation of MPI is an ISO C language lawyer, and very few users are.
The Fortran-specific text is similarly suggestive, but it only says that a user can pass a simply contiguous array, not that such a thing is required.
"In Fortran, one can pass the first element of a memory region or a whole array, which must be ‘simply contiguous’"
That's most probably because of the Fortran storage association "feature" which is more about how arrays were passed in pre-Fortran 90 times, i.e. it's legal for a caller C to pass some array element A(i) to a subprogram P accepting an array argument B(*) provided the effective size (that is the indices of B used in P match to valid indices of A).
The widespread use of MPI in the context of non-strict Fortran is a particularly good reason to clarify this ourselves rather than rely on ISO Fortran. As has been discussed many times in the passed, MPI relies on extensions and/or implementation-specific behavior with Fortran through the latest standard. Only with Fortran 2018 will this situation disappear. Jeff
Regards, Thomas -- Thomas Jahns HD(CP)^2 Abteilung Anwendungssoftware
Deutsches Klimarechenzentrum GmbH Bundesstraße 45a • D-20146 Hamburg • Germany
Phone: +49 40 460094-151 Fax: +49 40 460094-270 Email: Thomas Jahns <[email protected]> URL: www.dkrz.de
Geschäftsführer: Prof. Dr. Thomas Ludwig Sitz der Gesellschaft: Hamburg Amtsgericht Hamburg HRB 39784
_______________________________________________ mpiwg-rma mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-rma
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Jeff Hammond
