Re: [mpiwg-rma] Short question on the ccNUMA memory reality
Dave, thank you for this helpful answer. My question was related to
The sentence p436:45-46 "The order in which data is written is not specified unless further synchronization is used."
Your citation helps, because it tells the usual expectation:
1. Each CPU will always perceive its own memory accesses as occurring in program order. But in the MPI Standard nothing should be expected as usual.
The text p436:43-48 may be modified into Advice to users. If accesses in the RMA unified model are not synchronized (with locks or flushes, see Section 11.5.3), load and store operations might observe changes to the memory while they are in progress. The order in which data is written is not specified unless further synchronization is used. This might lead to inconsistent views on memory and programs that assume that a transfer is complete by only checking parts of the message are erroneous. NEW: The only consistent view is that each process will always perceive its own memory accesses as occurring in program order. (End of advice to users.) But one can argue that this is already expected by everyone. In my opinion, it is better to expect on MPI shared Memory windows only semantics that is written black on White in the MPI Standard. Best regards Rolf ----- Original Message -----
From: "Dave Goodell (dgoodell)" <[email protected]> To: "MPI WG Remote Memory Access working group" <[email protected]> Cc: "Bill Long" <[email protected]> Sent: Tuesday, August 5, 2014 6:10:01 PM Subject: Re: [mpiwg-rma] Short question on the ccNUMA memory reality
On Aug 5, 2014, at 2:53 AM, "Balaji, Pavan" <[email protected]> wrote:
On Aug 5, 2014, at 2:33 AM, Rolf Rabenseifner <[email protected]> wrote:
1. Question (sequential consistency on one location): ------------
Do I understand correctly that in the following patter on a shared Memory or a ccNUM shared memory
rank 0 rank 1 print x x=val_1 print x x=val_2 print x print x
the print statements can print only in the following sequence - some times the previous value - some times val_1 - and after some time val_2 and it then stays to print val_2
and that it can never be that a sequence with val_2 before val_1 can be produced, i.e., old_val val_2 val_1 val_2 is impossible.
When there are dependencies between statements, the compiler and architecture don’t reorder them.
Rolf, for a bit of clarification on this, I use Paul McKenney's theoretical "Ordering-Hostile Architecture" [1] as my guideline for what an arbitrary architecture might choose to do. ***This is separate from any language/compiler (non-)guarantees.***
[1] http://kernel.org/pub/linux/kernel/people/paulmck/perfbook/perfbook-e1.pdf
""" C.6.1 Ordering-Hostile Architecture A number of ordering-hostile computer systems have been produced over the decades, but the nature of the hostility has always been extremely subtle, and understanding it has required detailed knowledge of the specific hardware. Rather than picking on a specific hardware vendor, and as a presumably attractive alternative to dragging the reader through detailed technical specifications, let us instead de- sign a mythical but maximally memory-ordering-hostile computer architecture.4 This hardware must obey the following ordering con- straints [McK05a, McK05b]:
2. CPUs will reorder a given operation with a store only if the two operations are referencing different locations.
3. All of a given CPU’s loads preceding a read memory barrier (smp_rmb()) will be perceived by all CPUs to precede any loads following that read memory barrier.
4. All of a given CPU’s stores preceding a write mem- ory barrier (smp_wmb()) will be perceived by all CPUs to precede any stores following that write memory barrier.
5. All of a given CPU’s accesses (loads and stores) preceding a full memory barrier (smp_mb()) will be perceived by all CPUs to precede any accesses following that memory barrier. """
Point 2 is particularly relevant here.
Also other values are impossible, e.g., some bit or byte-mix from val_1 and val_2.
That is possible, unless you use some form of atomicity.
Right, though such "weird" patterns are most likely to occur due to some compiler behavior, not at the architectural level, assuming that "x" is word-sized or smaller and naturally aligned.
-Dave
_______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307)
participants (1)
Rolf Rabenseifner
