Re: [Mpi3-rma] [EXTERNAL] Re: Ticket for WG discussion
Hi Hubert, Thanks for your feedback. Here's updated text: ---8<--- MPI_Aint MPI_Aint_add(MPI_Aint base, MPI_Aint disp) This function produces a new MPI_Aint value that is equivalent to the sum of the base and disp arguments. The value of base may be relative to a non-zero value of MPI_BOTTOM that is unknown at the process performing the call to MPI_Aint_add. The addition is performed in a manner that results in the correct MPI_Aint representation of the address, as if the process that originally produced base had called: MPI_Get_address((char *) base + disp, &out_addr) ---8<--- Cheers, ~Jim. On 4/11/13 9:50 AM, Hubert Ritzdorf wrote:
Hi Jim,
I think the function works together with the RMA functions. But I have 3 comments to the function description.
I would replace
(*) is equal -> is equivalent Reason: You may not get the identical (same) value to base+disp, if you want to avoid the MPI_Aint overflow.; i.e. you may not able to compare them with "==".
(*) MPI_Get_address((char *) base + disp, &out_addr) -> MPI_Get_address((char *) MPI_BOTTOM + base + disp, &out_addr)
Reason: base is relative to MPI_BOTTOM
(*) Should disp not be of type MPI_Aint ? Otherwise, you may call MPI_Get_address((char *) MPI_BOTTOM + base + (1<<28)*sizeof(double), &out_addr) but not MPI_Aint_add (base, (1<<28)*sizeof(double)) on the same process.
I don' know whether the description should explicitly note, that it is not guaranteed that the user can compare addresses/displacements generated with
with addresses/displacements generated with
out_addr = MPI_Aint_add (base , disp)
Example: MPI_Get_addr() called on a 32-bit system MPI_Aint_add() called on a 64-bit system. MPI_Get_addr() might generate a negative displacement where MPI_Aint_add() might generate an equivalent positive displacement.
Best regards
Hubert
________________________________________ From: [email protected] [[email protected]] on behalf of Jim Dinan [[email protected]] Sent: Monday, April 08, 2013 11:30 PM To: [email protected] Subject: Re: [Mpi3-rma] [EXTERNAL] Re: Ticket for WG discussion
Hi Hubert,
Sorry it has taken me a long time to respond. I talked with Dave Goodell out here and he has (I think successfully) sorted me out with respect to how MPI_Aint addresses relative to different MPI_BOTTOM values work when passed around. So, I apologize for headaches relating to my misunderstandings of how these work.
The function we would like to propose is what was originally discussed:
MPI_Aint MPI_Aint_add(MPI_Aint base, int disp)
This function produces a new MPI_Aint value that is equal to base + disp. "base" may be relative to a non-zero value of MPI_BOTTOM that is unknown at the process performing the call to MPI_Aint_add. Therefore, the addition is performed in a manner that results in the correct address, as if the process that originally produced "base" had called:
Interested to hear your thoughts on this.
Cheers, ~Jim.
On 3/15/13 11:57 AM, Hubert Ritzdorf wrote:
I think, several kinds of addresses and displacements to MPI_BOTTOM are currently mixed up or we are discussing in different terminologies (or I missed some information).
After attaching memory, one process can sent AINT's (displacement to MPI_BOTTOM) to other processes and other processes can use these AINT's (displacements) in order to perform one sided operations:
Process A: Process B
MPI_Win_create_dynamic (info, comm, win) MPI_Win_create_dynamic (info, comm, win)
base_a = MALLOC (size_a) base_b = MALLOC (size_b) MPI_Win_attach (win, base_a, size_a); MPI_Win_attach (win, base_b, size_b)
// Get Displacement relative to MPI_BOTTOM(A) // Get Displacement relative to MPI_BOTTOM(B) MPI_Get_address (base_a, &disp_a); MPI_Get_address (base_b, &disp_b);
// Recv displacement from Process B // Recv displacement from A MPI_Irecv (&disp_b, 1, MPI_Aint, ...) MPI_Irecv (&disp_a, 1, MPI_Aint, ...)
MPI_Send (&disp_a, 1, MPI_Aint, ...) MPI_Send (&disp_b, 1, MPI_Aint, ....) MPI_Wait () MPI_Wait ()
MPI_Put (origin_addr_a, .... MPI_Put (origin_addr_b, ..., B, disp_b, count_a, type_a, win) A, disp_a, count_b, type_b, win);
This work's in C and Fortran, if MPI_Aint is sufficiently large.
Your original proposal doesn't work for Fortran :
Process A:
disp2 = MPI_Aint_index (base_b, index2)
MPI_Put (origin_addr_a2, ... B, disp2, count_a2, type_a2, win)
since you would use MPI_BOTTOM(Process A) instead of MPI_BOTTOM(Process B) in the computation of disp2.
In the heterogeneous case and using real displacements (note disp_b might be negative),
disp2 = MPI_Aint_index_disp (disp_b, index2)
might not work since the specific data (on heterogeneity) of the Process B is missing.
What's about (called in process A)
disp2 = MPI_Win_get_disp (win, B, disp_b, index2)
which computes the displacement for address (MPI_BOTTOM(B) + disp_b + index2) for Process B. The window win knows the address of MPI_BOTTOM(B) for dynamic windows or other bases for other window flavors.
A function
disp2 = MPI_Win_get_addr_disp (win, B, base_b, index2)
(base_b is an address stored in an MPI_Aint) would be also possible and would return the displacement for address ((char *) base_b + index2) in Process B relative to MPI_BOTTOM(B) (or the base address of other window flavors).
I hope, that I understood the problems correctly.
Hubert
________________________________________ From: [email protected] [[email protected]] on behalf of Jim Dinan [[email protected]] Sent: Friday, March 15, 2013 4:24 PM To: [email protected] Subject: Re: [Mpi3-rma] [EXTERNAL] Re: Ticket for WG discussion
Instead, how about a routine that converts MPI_Aints to be relative to a common MPI_BOTTOM so they mean something on other processes. We could define:
MPI_Aint_rebase(MPI_Aint in, MPI_Aint in_bottom, MPI_Aint *out, MPI_Aint out_bottom);
So, one could take the address from MPI_Win_attach and perform:
MPI_Aint_rebase(attach_addr, MPI_BOTTOM, &portable_addr, MPI_BOTTOM_COMMON);
The recipient would reverse this operation:
MPI_Aint_rebase(recv_addr, MPI_BOTTOM_COMMON, &addr, MPI_BOTTOM);
~Jim.
On 3/15/13 10:16 AM, Dave Goodell wrote:
We currently require MPI_Aint to have the same size and representation in both C and Fortran. So this would be a somewhat major departure...
-Dave
On Mar 15, 2013, at 10:04 AM CDT, Jim Dinan <[email protected]> wrote:
Given this MPI_BOTTOM awfulness, it seems like we need to add MPI_Aint_f2c/c2f() in order for dynamic windows to be reasonable from Fortran. To use dynamic windows, users must send aints from one process to another (after attaching memory). Given that Fortran aints are not portable across processes and C aints are, it seems like we need a way to make this conversion. And we will have to warn Fortran users that only C aints can be interpreted correctly in a different process.
~Jim.
On 3/14/13 12:18 PM, Hubert Ritzdorf wrote:
Ok,
this was one of the questions which was open to me. If you want to create an address (better displacement to MPI_BOTTOM) for another process you have to include the id (i.e. win, rank) of this process into MPI_Aint_index(). MPI_BOTTOM may be different in each process in Fortran and the local value of MPI_BOTTOM cannot be used.
Hubert ________________________________________ From: [email protected] [[email protected]] on behalf of Barrett, Brian W [[email protected]] Sent: Thursday, March 14, 2013 6:04 PM To: MPI 3.0 Remote Memory Access working group Subject: Re: [Mpi3-rma] [EXTERNAL] Re: Ticket for WG discussion
Hubert -
The issue with MPI_Get_address() in your usage model is one of heterogeneity. If process A is 32 bit and trying to create an address to talk to process B (which is 64 bit), there's now a difference (this, of course, assumes that MPI_Aint is an int64_t in that MPI).
Brian
-- Brian W. Barrett Scalable System Software Group Sandia National Laboratories ________________________________________ From: [email protected] [[email protected]] on behalf of Hubert Ritzdorf [[email protected]] Sent: Thursday, March 14, 2013 10:56 AM To: MPI 3.0 Remote Memory Access working group Subject: [EXTERNAL] Re: [Mpi3-rma] Ticket for WG discussion
Hi Jim,
this sounds to me that
addr2 = MPI_Aint_index (base, disp)
is equivalent to
MPI_Get_Address ((char *) base + disp, &addr2)
Is this correct or where is the difference ?
Or is "base" also a displacement relative to MPI_BOTTOM (in which case it might be signed in Fortran) and
is equivalent to
MPI_Get_address ((char *) MPI_BOTTOM + base + disp, &addr2)
Hubert ________________________________________ From: [email protected] [[email protected]] on behalf of Jim Dinan [[email protected]] Sent: Thursday, March 14, 2013 4:05 PM To: [email protected] Subject: Re: [Mpi3-rma] Ticket for WG discussion
A little clearer:
The value returned is the address, relative to MPI_BOTTOM, resulting from the sum of base and disp.
~Jim.
On 3/14/13 9:42 AM, Jim Dinan wrote:
Hi Hubert,
My apologies, the ticket is light on details. The proposed function is:
MPI_Aint MPI_Aint_index(MPI_Aint base, MPI_Aint disp);
This function interprets the base argument as an address relative to MPI_BOTTOM and the disp argument as a signed integer displacement. The value returned is the sum of these two values.
~Jim.
On 3/13/13 7:12 AM, Hubert Ritzdorf wrote:
Hi Jim,
Sorry, I have some problems with the interpretation of function MPI_Aint_index().
(*) What does MPI_Aint_index() return ? A target displacement which can be used in RMA functions such as MPI Put/Get or does it return an address such as MPI_Get_address () ?
(*) What is argument "base" ? An address returned by MPI_Get_address() of any address or a window base returned by MPI_Win_get_attr(win, MPI_WIN_BASE, &base, &flag) ? May "base" (as MPI_Aint) be transferred from a different process ?
Hubert ________________________________________ From: [email protected] [[email protected]] on behalf of Jim Dinan [[email protected]] Sent: Tuesday, March 12, 2013 9:08 PM To: [email protected] Subject: Re: [Mpi3-rma] Ticket for WG discussion
Hubert,
We have added a solution #3 to the ticket based on discussion in the working group today. That's our current proposal. Could you take a look and see if that will be Fortran compatible?
Thanks, ~Jim.
On 3/12/13 2:28 PM, Hubert Ritzdorf wrote:
concerning Ticket 349. (*) In Fortran, the displacement for dynamic windows may be signed since MPI_BOTTOM of Fortran is not (void *) NULL.. (*) Fortran doesn't have unsigned integers, thus you cannot use a Fortran version of MPI_Disp for arithmetics (such as disp++). (*) MPI Displacements in general may be signed. They might be relative to any address.
Therefore, I can't see that the Proposed Solution 2 solves the problem.
Hubert
________________________________________ From: [email protected] [[email protected]] on behalf of Jim Dinan [[email protected]] Sent: Tuesday, March 12, 2013 5:12 PM To: MPI 3.0 Remote Memory Access working group Subject: [Mpi3-rma] Ticket for WG discussion
Hi All,
I would like to propose the following two tickets for discussion in today's WG meeting:
https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/349 https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/344
#349 is a bugfix that definitely needs to be addressed. #344 is an "elegance of the interface" ticket where I would like to poll the WG to determine the level of support and determine if this should be pursued.
I unfortunately need to duck out at 4pm today, so if possible, I propose that we discuss these at the beginning of the meeting.
Thanks! ~Jim. _______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
Click https://www.mailcontrol.com/sr/kHf7UuVmhqHGX2PQPOmvUu5zZAYN1MosNz2OH0bOQrlt5... to report this email as spam.
participants (1)
Jim Dinan
