Re: [Mpi3-rma] nonblocking MPI_Win_create etc.?
The reason to put windows on subgroups is to avoid the O(N) metadata in the window associated with registered memory. For example, on BGP a window has an O(N) allocation for DCMF memregions. In the code my friend develops, N=300000 on comm_world but N<200 on a subgroup. He is at the limit of available memory, which is what motivated the use case for subgroup windows in the first place. I do not see how one can avoid O(N) metadata with MPI_Win_create_dynamic on comm_world in the general case, unless one completely abandons RDMA. How exactly does registered memory become visible when the user calls MPI_Win_attach? Jeff On Thu, Sep 22, 2011 at 4:58 PM, Rajeev Thakur <[email protected]> wrote:
In the new RMA, he could just call MPI_Win_create_dynamic once on comm_world and then locally attach memory to it using MPI_Win_attach. (And avoid using fence synchronization.)
Rajeev
On Sep 22, 2011, at 4:25 PM, Jeff Hammond wrote:
I work with someone who has a use case for nonblocking window creation because can get into a deadlock situation unless he does a lot of bookkeeping. �He's creating windows on subgroups of world that can (will) overlap. �In order to prevent deadlock, he will have to do a global collective and figure out how to order all of the window creation calls so that they do not deadlock, or in the case where that requires solving an NP-hard problem (it smells like the scheduling problem to me) or requires too much storage to be practical (he works at Juelich and regularly runs on 72 racks in VN mode), he will have to serialize window creation globally.
Nonblocking window creation and a waitall solves this problem.
Thoughts? �I wonder if the semantics of nonblocking collectives - which do not have tags - are even sufficient in the general case.
Jeff
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/index.php/User:Jhammond _______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
participants (1)
Jeff Hammond
