Re: [Mpi3-rma] request-based ops
Jim, You cannot do this in WAIT, as I might do a loop on TEST. In fact, that's the primary use case for nonblocking requests, IMO. You can stick a request into an array of other requests to check on any of them. Please see the slides that Wesley presented. We should not be reiterating what was already presented at the Forum on the email list. -- Pavan On 06/14/2013 12:23 PM, Jim Dinan wrote:
Jeff,
How would iwin_flush be different in practice from doing nothing? I can give you a trivial implementation that does nothing until you wait on the request, at which point I call blocking win_flush. With my implementor hat on, I would view this function as a performance hint that indicates to the implementation that you will want to complete all operations thus far and none after. Given a high quality implementation that actually makes background progress on one-sided communications, this should be unnecessary and I would probably implement it as above. If you want to only complete specific operations, the request generating functions are available.
~Jim.
On Fri, Jun 14, 2013 at 11:09 AM, Jeff Hammond <[email protected] <mailto:[email protected]>> wrote:
Yes, I was making a disingenuous argument to push back against the fallacy that iwin_flush is not required.
Jeff
On Fri, Jun 14, 2013 at 10:25 AM, Jim Dinan <[email protected] <mailto:[email protected]>> wrote: > Hey now, blocking doesn't mean that MPI /must/ block, it only means that it > /can/ block. Blocking and synchronizing are certainly not the same; Ssend > synchronizes, which is a stronger semantic than blocking. > > ~Jim. > > > On Wed, Jun 12, 2013 at 5:07 PM, Jeff Hammond <[email protected] <mailto:[email protected]>> wrote: >> >> Sure, let's separate these issues. I think Pirate RMA (RRPUT, >> RRACCUMULATE and RRRGET_ACCUMULATE) is a more _local_ solution in the >> MPI standard sense :-) >> >> SEND is also a nonblocking operation because the implementation can >> always buffer the data and return before the remote RECV is posted. >> Only SSEND is blocking if one asserts that blocking is equivalent to >> "requires remote agency to complete". >> >> So basically, I completely agree with the Forum back-pushers that >> IWIN_FLUSH etc. are as useful as ISEND. >> >> Jeff >> >> On Wed, Jun 12, 2013 at 4:58 PM, Pavan Balaji <[email protected] <mailto:[email protected]>> wrote: >> > >> > The push-back at the Forum was that WIN_FLUSH and WIN_UNLOCK are local >> > operations (in MPI's definition of local), so they are already >> > nonblocking. >> > I was not at the Forum. I pointed out to Wesley after he returned that >> > they >> > are only local in the simple case where no one else is holding the lock. >> > Otherwise they are not. >> > >> > Further, the proposal is not only about WIN_FLUSH and WIN_UNLOCK. It >> > was >> > for a long list of blocking functions: COMM_ACCEPT, COMM_CONNECT, >> > WIN_FENCE, >> > WIN_COMPLETE, WIN_WAIT, WIN_UNLOCK, WIN_FLUSH, WIN_FLUSH_LOCAL, >> > WIN_FLUSH_ALL, WIN_FLUSH_LOCAL_ALL, ... The point was that MPI should >> > deal >> > with concepts, not specific function exceptions. Nonblocking >> > communication >> > is one such concept, and it should be valid for all operations (that are >> > not >> > local). >> > >> > FWIW, my proposal was only to add nonblocking variants to blocking >> > calls. >> > Adding extra per-op remote completion requests is a separate issue and >> > should not be mixed with this. I personally think it's useful (in fact, >> > my >> > original proposal for RPUT/RGET equivalents had it), but that's still a >> > separate issue. >> > >> > -- Pavan >> > >> > >> > On 06/12/2013 09:41 AM, Jeff Hammond wrote: >> >> >> >> So Wes was telling me about IWIN_FLUSH yesterday (this function is a >> >> great idea, btw) and the alternative of adding double-request RPUT and >> >> RACCUMULATE that provide a request for both local and remote >> >> completion. By induction, this would imply a triple-request >> >> RGET_ACCUMULATE operation, which I also think is a good idea. It's >> >> really silly to have to wait for the result buffer to be ready to >> >> reuse the origin buffer in RGET_ACCUMULATE. It seems that many >> >> implementations will be able to send the entire origin buffer a >> >> nontrivial amount of time before the result comes back, particularly >> >> if the remote side doesn't have hardware-based progress and the data >> >> has to wait in a network buffer. >> >> >> >> I'm sorry that I missed the last day of the Forum in San Jose. I >> >> didn't know these operations were on the table. They sound like a >> >> great idea to me. >> >> >> >> Jeff >> >> >> > >> > -- >> > Pavan Balaji >> > http://www.mcs.anl.gov/~balaji >> >> >> >> -- >> Jeff Hammond >> Argonne Leadership Computing Facility >> University of Chicago Computation Institute >> [email protected] <mailto:[email protected]> / (630) 252-5381 >> http://www.linkedin.com/in/jeffhammond >> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond >> ALCF docs: http://www.alcf.anl.gov/user-guides >> _______________________________________________ >> mpi3-rma mailing list >> [email protected] <mailto:[email protected]> >> http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma > > > > _______________________________________________ > mpi3-rma mailing list > [email protected] <mailto:[email protected]> > http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] <mailto:[email protected]> / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond ALCF docs: http://www.alcf.anl.gov/user-guides _______________________________________________ mpi3-rma mailing list [email protected] <mailto:[email protected]> http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
_______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
