Re: [mpiwg-rma] Fence + threads
William Gropp <[email protected]> writes:
After all, it is (as it should be) incorrect for two threads in the same process to call MPI_Barrier on the same communicator, even though we could define the semantics in this specific situation.
I don't see a serious use case for that, and it's natural to lump in with the other collectives. Consider this use case for MPI_Win_fence: In a multi-layer geophysical flow, there exists stiff coupling in the vertical with sufficiently large data sizes to justify a horizontal-only decomposition over MPI ranks, but some other processes are contained within layers (e.g., gravity waves in the ocean) which are subcycled, justifying a vertical decomposition across threads. Different layers may subcycle a different number of times. Bill has a cartoon slide advocating decompositions of this sort for future systems. A similar layout could arise in non-square dense linear algebra where instead of creating 1D subcomms for row and column blocks, one of the decomposition directions only uses threads. I would expect the computation to be more regular for DLA and thus less compelling than the stratified flow example, but irregularity would be present for adaptive H-matrix methods, for example. If someone wants to use windows for the MPI communication in this case and if MPI_Win_fence cannot be overlapped from threads, what should the user do? Create different windows for each layer? What if their scheme depends on adjacent layers (so that there is overlap)?
participants (1)
Jed Brown
