Re: [Mpi3-rma] Disp_unit in allocate_shared should be returned by win_shared_query?
On 7/18/12 1:06 PM, Torsten Hoefler wrote:
On Wed, Jul 18, 2012 at 01:08:43PM -0500, Pavan Balaji wrote:
On 07/18/2012 01:02 PM, Torsten Hoefler wrote:
Jim,
Is one process' disp_unit meaningful at another process? I thought that this is not the case. MPI provides no other routines to query another process' disp_unit. It is something that the user is passing in. I don't know of a particular use-case but we can query all other arguments that each process passed. One more integer seemed safe to me.
Also, what meaning does a disp_unit have in the context of load/store operations that will result from win_shared_query? Nothing.
Maybe I'm missing something, but this doesn't seem necessary. Well, it's better to have it than to introduce it with a different name later. That was my main motivation. One could also use it in a library context to query. But that's weak, I know.
This doesn't seem critical, and can always be added in MPI-3.1 if we find it necessary. No reason to rush it.
It cannot be added without a new function name. That was the concern here. Adding it seems less risk than not adding it. In addition, it is already added ;-).
I am concerned that this is a harmful change. The disp_unit from one process has no meaningful use at another process. If the user wants to know it for some reason, they can use a separate communication operation. ~Jim.
participants (1)
Jim Dinan
