Re: [mpiwg-rma] Fence + threads
That’s a good assumption and I’d be in favor of formally mentioning that in the standard. Do you want to file a ticket? (unfortunately, I don’t think it’s a chapter committee issue). — Pavan On Jun 20, 2014, at 1:36 PM, Rajeev Thakur <[email protected]> wrote:
I always assumed that concurrent calls from multiple threads to collective functions on the same comm, win, or fh are not allowed. For example, there is also a collective MPI_File_sync(fh).
Rajeev
On Jun 20, 2014, at 1:32 PM, "Balaji, Pavan" <[email protected]> wrote:
Right. We don’t say something similar for windows. Was it intentional or just an accidental ommission?
— Pavan
On Jun 20, 2014, at 1:29 PM, Rajeev Thakur <[email protected]> wrote:
FWIW, the collective communication chapter says this on 217:24-27.
"Finally, in multithreaded implementations, one can have more than one, concurrently executing, collective communication call at a process. In these situations, it is the user's responsibility to ensure that the same communicator is not used concurrently by two dierent collective communication calls at the same process."
On Jun 20, 2014, at 1:18 PM, "Balaji, Pavan" <[email protected]> wrote:
That doesn’t disallow it. It just says the ordering is arbitrary, which is OK in my example.
— Pavan
On Jun 20, 2014, at 1:16 PM, Rajeev Thakur <[email protected]> wrote:
There is this text on pg 484, ln 18-22
"Collective calls: Matching of collective calls on a communicator, window, or file handle is done according to the order in which the calls are issued at each process. If concurrent threads issue such calls on the same communicator, window or file handle, it is up to the user to make sure the calls are correctly ordered, using interthread synchronization."
Rajeev
On Jun 20, 2014, at 1:11 PM, "Balaji, Pavan" <[email protected]> wrote:
The standard itself doesn’t seem to disallow it. This means that, at least, MPICH is incorrect here. I’d expect most MPICH derivatives to be incorrect for this as well.
However, I’m trying to understand if that was the intention (and just forgotten to describe in the standard). We never discussed this in the MPI-3 working group.
— Pavan
On Jun 20, 2014, at 12:46 PM, Dave Goodell (dgoodell) <[email protected]> wrote:
On Jun 20, 2014, at 11:16 AM, "Balaji, Pavan" <[email protected]> wrote:
Is the following code correct? Two threads of a process both do the following:
MPI_PUT MPI_PUT MPI_WIN_FENCE
Collectives are not allowed on the same communicator simultaneously. But we don’t say anything similar for windows.
As I read it, it should be fine according to the standard as long as you haven't specified any assertions that would cause you to be lying to the implementation.
When we don't specifically disallow concurrent multithreaded operations, then the general threading text seems to allow this. See MPI-3, p.483, l.1-11:
----8<---- The two main requirements for a thread-compliant implementation are listed below.
1. All MPI calls are thread-safe, i.e., two concurrently running threads may make MPI calls and the outcome will be as if the calls executed in some order, even if their execution is interleaved.
2. Blocking MPI calls will block the calling thread only, allowing another thread to execute, if available. The calling thread will be blocked until the event on which it is waiting occurs. Once the blocked communication is enabled and can proceed, then the call will complete and the thread will be marked runnable, within a finite time. A blocked thread will not prevent progress of other runnable threads on the same process, and will not prevent them from executing MPI calls. ----8<----
So, absent some external inter-thread synchronization, it will be undefined exactly which epoch the MPI_PUTs end up in.
-Dave
_______________________________________________ mpiwg-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-rma
participants (1)
Balaji, Pavan
