Re: [Mpi3-rma] FW: MPI 3 RMA Examples needed
To add to Robert's point about non-scalable metadata (remote addresses etc.), it will prohibitively expensive to use Global Arrays (GA) on our next machine without remote method invocation (RMI). According to the Internet [1], that machine will have ~0.75M cores. In the most minimal scenario (8 bytes per remote address), that's 6 MB to index the whole machine, if one is going to run one process per core. If one estimates using IB metadata with static all-connectivity (stupid, of course), 44 kB * 0.75M = 33 GB, which is impossible. While globally-scoped arrays are probably a poor idea to start with, some applications will try to use them. If one stores only one copy of metadata per node, O(50K)*sizeof(metadata) = 50 MB per array if one is fairly stingy. A feature I hope to use to ameliorate this problem is to run RMA through a metadata server. One can do this right now with put/get, but the latency will be worse than with RMI. At present, one would have to do two remote gets, a blocking one to the metadata server, and then the acquisition of the actual data. With RMI, the metadata operation need not block on the initiator and requires two active-messages and the put from the remote location to the initiator. Assuming we cross the 2M node barrier in ~2015, the only practical way to have globally-scoped data will be to use hierarchical metadata servers, where the lack of RMI will lead to even less efficient remote metadata acquisition. It would not surprise me if the get(+get)^tiers method for RMA will be an order-of-magnitude slower than the (RMI)^tiers+put method, given the likelihood of network contention across a hierarchical network at this scale. While we can debate the sanity of globally-scoped data at exascale, there will always be science which is not amenable to simple domain decomposition and thus requires some type of global view. Whether the data structures are simple ala GA or complex ala Madness, RMI is the only sensible ways to implement these involve RMI. Jeff On Sun, Jan 31, 2010 at 2:00 PM, Robert Harrison <...> wrote:
Bill,
A compelling and near universal example is maintaining and updating remote data structures. �Only arrays or simple static data structures can be treated efficiently with RMA, and even this assumes a non-scalable replication of addresses across all nodes. �More complex structures (trees, hash tables, ...) and scalable solutions even for arrays require remote method invocation to access state and to perform some computation.
This example also motivates considerations of optional message ordering (for sequential consistency), optional atomicity (for correctness with multiple updaters), etc. �Even within a single application there is utility for different variants.
Some remote operations will return a value and how to do so efficiently without running into network/NIC flow problems seems to be an issue.
A concrete example is the sparse tree (in dimensions 1,2,..,6) in madness. These are stored in distributed hash tables. �Minimally, we must be able to insert, erase, replace, and read entries. �More generally the entries are objects and we wish to invoke their methods so that applications can be composed in the spirit of Charm++ ... messaging between objects addressed by their name in a namespace (container).
Best wishes
� Robert
-- Jeff Hammond Argonne Leadership Computing Facility [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond
participants (1)
Jeff Hammond
