Re: [Mpi3-rma] MPI_Fetch_and_op and predefined datatypes
Those types are listed in Section 5.9.4, not Section 5.9.2. As Hubert's original proposal made explicit reference to 5.9.2 and not "anything predefined for reductions" (or equivalent), I think that his text changes exclude the types that were designed to work with MPI_MINLOC and MPI_MAXLOC. Does F*Op work with those predefined operations? What does it even mean to do those in F&Op anyways? Jeff On Fri, Oct 26, 2012 at 11:34 PM, Jim Dinan <[email protected]> wrote:
Did we also intend to include pair types for F&Op? They are allowed in reductions.
~Jim.
On 10/26/12 4:07 PM, Torsten Hoefler wrote:
On Fri, Oct 26, 2012 at 04:22:02PM -0500, Jeff Hammond wrote:
I don't want to wait for 3.1. Are we seriously going to require MPI_WCHAR support in F&Op to be MPI-3 compliant? That makes no sense.
I think the intent of "Any of the predefined operations for MPI_REDUCE, as well as MPI_NO_OP or MPI_REPLACE, can be specified as op; user-defined functions cannot be used." is clear. One could even dream up a use-case for MPI_WCHAR if one wants to emulate an atomic read (using MPI_NO_OP).
I will not vote against an errata if you want to propose text and initiate the process.
Best, Torsten
_______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
participants (1)
Jeff Hammond
