Re: [Mpi3-rma] Target displacement sign issue
Breaking backwards compatibility is worse than whatever portability issues you can come up with, especially with something as fundamental as MPI_Aint. Jeff On Tue, Aug 28, 2012 at 1:45 PM, Dries Kimpe <[email protected]> wrote:
* Jeff Hammond <[email protected]> [2012-08-28 13:22:47]:
I imagine that HPC-oriented operating systems do not provide virtual addresses in the problematic range anyways. Maybe VM randomization causes this but that's not common in HPC.
In any case, MPI RMA requires MPI_Alloc_mem for portable performance. MPI_Alloc_mem should be capable of returning only pointers in the lower half of the address space, if by no other means than using mmap intelligently.
I believe that this is only a problem on 32-bit systems where losing 2 of the 4 GB is a problem. On a 64-bit system, losing half of the 18 exabytes in the address space is unlikely to be a problem, given that an exabyte of DRAM would require something like a white dwarf to power, meaning that it is likely that the OS can find a way to VM map the physical memory present into the lower half of the address range.
On 32 bit, it is very likely that addresses from the stack variables will have the highest bit set. This is even more true for 32 bit programs running under 64 bit kernels.
In linux, on 64 bit X86_64, this will _currently_ not be a problem. All user memory will be between 0000000000000000 - 00007fffffffffff.
Also, remember that these are virtual addresses. If MPI_Alloc_mem is calling malloc/new (which can call mmap for large allocations), addresses will be from the high range, which can have the sign bit set.
But all this is besides the point. The address map/choices are not fixed, and can change at any time (and do differ between operating systems), and MPI cannot change how the C library/runtime returns memory from malloc.
(And then we're ignoring tools like valgrind/memory profilers/...)
Ignoring the sign issue will very likely cause portability issues.
Dries _______________________________________________ mpi3-rma mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-rma
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
participants (1)
Jeff Hammond
