Re: [mpiwg-persistence] Unused persistent collectives info keys in Annex
Hi, thank you... we will issue an appropriate change to remove these... they are not part of ticket #25 as approved...and so we must issue an erratum on ticket #25. They split off into ticket #83 in March, 2018. We itrerated multiple times on having or not having these info keys as part of ticket #25 and we must have missed removing completely. Such info keys are part of a second viable ticket we that we split out are still working on ... none belong in the standard yet. The first key value is part of ticket 83 as of now... which will get a no no plus vote in December (it had its reading priorly), introducing the first key... since acceptance is anticipated. Only examples for this ticket need to be fixed. Plus now evidently Annex 1.5 :-) too. The second and third key values are currently part of no proposed ticket. They are vestigial. So, our plan is to remove all mention of them with appropriate process and then watch for the passage of 83. :-) I will make sure that no no vote ticket for 83 also includes adding the first key to the Annex 1.5. I will ask Bill Gropp and Martin Schulz for advice on fixing this. They are cc’d. Tony Anthony Skjellum, PhD 205-807-4968
On Aug 29, 2019, at 5:12 AM, Joseph Schuchart <[email protected]> wrote:
Tony,
I just rebased my MPI PR to the MPI 4.x branch. Looking at the info keys, I found that there are info keys in Annex A.1.5 that stem from the persistent collectives chapter but the text mentioning them was commented out there (git blame mentions you as the last author of that part). It seems that the info keys in the annex are a relic of this text. The keys in question are:
mpi_assert_strict_start_ordering mpi_optimization_goal mpi_reuse_count
Are you planning to revive these keys or should they be removed?
Best regards, Joseph -- Dipl.-Inf. Joseph Schuchart High Performance Computing Center Stuttgart (HLRS) Nobelstr. 19 D-70569 Stuttgart
Tel.: +49(0)711-68565890 Fax: +49(0)711-6856832 E-Mail: [email protected]
participants (1)
Skjellum, Anthony
