Re: [mpiwg-p2p] Next meeting: 14th April 2014 11am Central US
Is anyone else having trouble connecting to the meeting? I've tried multiple machines here at ANL. On 04/13/2014 05:24 AM, Daniel Holmes wrote:
Hi all,
The next point-to-point teleconference will be on Monday 14th April 2014 at 11am Central US via webex.
Connection details are on the p2p wiki.
Agenda: 1) Streams: I have some notes - see below - from a discussion last week with Bill Gropp, Torsten (et al from the EPiGRAM project) 2) Receive_reduce 3) Arecv 4) AOB (= any other business)
Cheers, Dan.
Streams ======= QCDOC developers want persistent channel semantics; actually use one-sided, multi-value variables Breaking message boundaries enables pipe-lining - makes it fundamentally different to RMA? Libraries exist to do this - what are they? Streaming is well defined in OpenSPL Papers from the MPI-2 era (about RMA) suggest writing papers on this and getting feedback Reach out to other communities, e.g. SKA - Square Kilometre Array Should this be added to MPI or added as a library on top - does this need small enabling changes Bill suggests we craft a broad-visibility paper Affects the discussion on Arecv, which would be handled by streams? Getting MPI to manage/allocate memory (as in Arecv) is dangerous and bad
Flow-control ============ May just be remote notification and a sequence of messages that remove the need for local notification - reduces protocol messages (from 3 to 1 per message) Integral part of streaming - turns global flow-control problem into local buffer management May address load-imbalance? Hmm
participants (1)
Kenneth Raffenetti
