Re: [mpiwg-p2p] Ordering of P2P messages in multithreaded applications
Hi Joachim, There is no guarantee of ordering between the two sends because they are logically concurrent. If they were issued on the same thread then MPI guarantees delivery order will be identical to the sequential issuing order. Many MPI libraries are very likely to deliver these messages "in order”, that is, the first one to be called chronologically at the sender process is likely to leave first and therefore likely to arrive first. Interleaving execution of the sending threads may change the issuing order on the network and out-of-order networks may change the order of arrival. On the other hand, if an MPI implementation is internally using sequence numbers (or a similar mechanism) to enforce ordering for the same-thread case, then it may also (incidentally) reconstruct the issuing order for this case. However, you cannot rely on this behaviour being portable from system to system or from MPI library to MPI library. If you wish to enforce a particular ordering of these messages, then you can use tags to differentiate each from the other. There is an argument for always using tags in this type of situation to increase program readability. Cheers, Dan. — Dr Daniel Holmes PhD Applications Consultant in HPC Research [email protected]<mailto:[email protected]> Phone: +44 (0) 131 651 3465 Mobile: +44 (0) 7940 524 088 Address: Room 2.09, Bayes Centre, 47 Potterrow, Central Area, Edinburgh, EH8 9BT — The University of Edinburgh is a charitable body, registered in Scotland, with registration number SC005336. — On 15 Nov 2018, at 04:16, Joachim Protze via mpiwg-p2p <[email protected]<mailto:[email protected]>> wrote: Hi all, I have a question on the "Semantics of Point-to-Point Communication" in a multithreaded context. For me the situation for the code below is not clear, especially with respect to the paragraph in MPI-3.1 p.41, l.10-17 : void test(int rank) { int msg = 0; if (rank == 0) { #pragma omp parallel num_threads(2) #pragma omp critical { MPI_Send(&msg, 1, MPI_INT, 1, 42, MPI_COMM_WORLD); msg++; } } else if (rank == 1) { MPI_Recv(&msg, 1, MPI_INT, 0, 42, MPI_COMM_WORLD, MPI_STATUS_IGNORE); printf("Received %i\n", msg); MPI_Recv(&msg, 1, MPI_INT, 0, 42, MPI_COMM_WORLD, MPI_STATUS_IGNORE); printf("Received %i\n", msg); } } Two threads on the first process send a message, the first thread sends 0, the second thread send 1. From OpenMP semantics, the first send happens before the second send. Is there a guarantee, that the other process receives the 0 first? Thanks, Joachim -- Dipl.-Inf. Joachim Protze IT Center Group: High Performance Computing Division: Computational Science and Engineering RWTH Aachen University Seffenter Weg 23 D 52074 Aachen (Germany) Tel: +49 241 80- 24765 Fax: +49 241 80-624765 [email protected]<mailto:[email protected]> www.itc.rwth-aachen.de _______________________________________________ mpiwg-p2p mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-p2p The University of Edinburgh is a charitable body, registered in Scotland, with registration number SC005336.
participants (1)
HOLMES Daniel
