Re: [mpiwg-p2p] [MPIWG Fortran] FP16 16-bit-floating-point
(we never did the MAX/MINLOC reductions also for fixed-size types)
Yes, because it leads to an absurd explosion of enumerations, which is why I proposed a utility routine to construct pair types that behave like built-ins ( https://github.com/mpi-forum/mpi-issues/issues/18#issuecomment-155661199). While it's embarrassing that MPI has failed to keep up with ISO language built-in types, I console myself with the fact that I can implement all of this in BigMPI or MPICH in a day or two and Open-MPI with more effort. I don't know where float128_t sits w.r.t. ISO standardization in C or C++ but users have been asking for __float128 support for a long time to no avail. Jeff On Fri, Jun 16, 2017 at 11:04 AM, Rolf Rabenseifner <[email protected]> wrote:
Atsushi-san, (now only in the P2P-WG)
http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2016/p0192r0.pdf http://www.open-std.org/jtc1/sc22/wg14/www/docs/n2016.pdf
Therefore for the C-side, I would propose for (oc course voted in only after the C standardization gets confirmed)
MPI-3.1 table on page 673
Named Predefined Datatypes | C types ---------------------------+------------ MPI_SHORT_FLOAT | short float MPI_FLOAT16_T | float16_t MPI_FLOAT32_T | float32_t MPI_FLOAT64_T | float64_t
(We must check, whether they also include float128_t into the C Standard, or whether they only standardize short float without all ..._T)
MPI-3.1 table on page 675 lines 1-9
Datatypes for reduction functions (C) ------------------------------------- MPI_SHORT_FLOAT_INT
MPI-3.1 Table 13.2 on page 540 ***and*** MPI-3.1 Table 3.2 on page 26
Type | Length ----------------+------- MPI_SHORT_FLOAT | 2 MPI_FLOAT16_T | 2 MPI_FLOAT32_T | 4 MPI_FLOAT64_T | 8
And adding the following to "Floating point:" on page 176, line 45:
- before MPI_FLOAT: MPI_SHORT_FLOAT, - after MPI_DOUBLE: MPI_FLOAT16_T, MPI_FLOAT32_T, MPI_FLOAT64_T,
By the way, the table on page 540 should be done with normal Latex and the correct macros for constants to guarantee that this Location is also visible in the constants-index page 823ff.
You may have detected further Locations that are relevant.
And of course, the appropriate change-log index is also needed.
Best regards Rolf
----- Original Message -----
From: "Kawashima, Takahiro" <[email protected]> To: "MPI WG Point To Point Communications working group" < [email protected]> Cc: "Rolf Rabenseifner" <[email protected]>, "MPI-WG Fortran working group" <[email protected]>, "Anthony Skjellum" <[email protected]>, "Reinhold Bader" < [email protected]>, "Atsushi Hori" <[email protected]>, "fortran standards email list for J3" < [email protected]> Sent: Friday, June 16, 2017 3:16:57 PM Subject: Re: [mpiwg-p2p] [MPIWG Fortran] FP16 16-bit-floating-point
I don't know the status of C standardization nor contact person but the suggestion of 'short float' was seem to made in a WG.
Regards, Takahiro Kawashima, Fujitsu
Tony,
we try to find the type names used in C and Fortran before we define the new predefined MPI datatype handles for representing those language types.
Who knows, whom we can contact on the C standardization side?
Best regards Rolf
From: "Anthony Skjellum" <[email protected]> To: "MPI WG Point To Point Communications working group" <[email protected]> Cc: "Reinhold Bader" <[email protected]>, "Atsushi Hori" <[email protected]>, "fortran standards email list for J3" <[email protected]>, "MPI-WG Fortran working group" <[email protected]> Sent: Friday, June 16, 2017 2:50:00 PM Subject: Re: [MPIWG Fortran] [mpiwg-p2p] FP16 16-bit-floating-point
Rolf, apart from the Fortan angle, may I strongly encourage that we adopt this datatype for MPI-4. It is part of real MPI codes already, but now we have to fake transfer datatypes as 16-bit integers or bytes... which means not really right if heterogeneous interoperability were to be maintained. And this is a canonical IEEE type now, as you note. There is also the "2 half-float" datatype (32-bits) at least in CUDA to be looked at; maybe ignored or maybe supported, but it is there too. Key to this MPI users and applications use half floats and 2 half-floats :-) in practice.
May I also suggest a forward look at the types in AVX-512, in case any of these become particularly relevant in future. At least 8-bit integers are conceptually new, apart from BYTE. [ https://en.wikipedia.org/wiki/AVX-512 | https://en.wikipedia.org/wiki/AVX-512 ]
Regards, Tony
On Fri, Jun 16, 2017 at 6:52 AM, Rolf Rabenseifner < [ mailto:[email protected] | [email protected] ] > wrote:
Hi all together,
I'm sitting in the MPI Forum Meeting and we discuss the new IEEE FP16 datatype.
Questions to the Fortran atandardization body:
- Does the Fortran Standardization Body has already a proposal for the new name in Fortran for this IEEE FP16?
- Will be REAL*2 identical to IEEE FP16?
Best regards Rolf
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . _______________________________________________ mpiwg-p2p mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-p2p
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Jeff Hammond
