Puri: embiggening instructions
Puri -- Per our discussion earlier this week, you're going to embiggen the collective chapter so that we can show it in ABQ this week. Here's what you need to know: 1. Clone Martin's fork: https://github.com/martinruefenacht/mpi-standard 2. Check out the feat-modern-lang-bindings branch 3. Edit the collective .tex: 3a. Per the embiggening text and https://docs.google.com/presentation/d/13X_4moTKxIHB0YJI-bBlJ5V3bF2WywB1DfOO..., selectively embiggen arguments 3b. You embiggen types by changing the 2nd arg to parameter() to a "POLY" type. Here's the POLY types that we have defined: - POLYDISPLACEMENT - POLYDTYPE_NUM_ELEM -- used in the datatype chapter; we might need to revisit this one...? - POLYNUM_BYTES -- ditto (datatype chap/might need to revisit) - POLYXFER_NUM_ELEM I'm guessing you'll use POLYDISPLACEMENT and/or POLYXFER_NUM_ELEM. I used POLYXFER_NUM_ELEM in the pt2pt chapter (e.g., for MPI_SEND and MPI_RECV and friends). If you need old POLY types, let us know. ----- You can "make 4cleandoc" at the top level to make an mpi-report.pdf in the MPI-4 / embiggened style. For any function with POLY types, you should see a 2nd "_l" C binding, and 2 x MPIF08 bindings (with no "_l" suffix). "make 3cleandoc" (or just "make cleandoc") will make mph-report.pdf in the MPI-3 / not-embiggened style. You can do the same thing in the chapter directory, but you'll need to edit Makefile.chap and change RENDER_MODE = 3.1 to RENDER_MODE = 4.0 Then you can cd chap-coll make To make just the collectives chapter PDF (coll.pdf). It's probably a LOT quicker than building the entire cleandoc. In case you need it, wiki for the regular Pythonizing directions (which doesn't really say anything about Embiggening yet) is here: https://github.com/mpiwg-large-count/large-count-issues/wiki/pythonizing -- Jeff Squyres [email protected]
participants (1)
Jeff Squyres (jsquyres)
