Re: [Mpiwg-large-counts] Large Count - the principles for counts, sizes, and byte and nonbyte displacements
Agreed -- that ticket was made as an action item from *before* the recent webex / before the current understanding. On Nov 5, 2019, at 9:18 AM, HOLMES Daniel via mpiwg-large-counts <[email protected]<mailto:[email protected]>> wrote: Hi Rolf (et al), I wrote a lengthy comment on that issue to capture my current understanding of your “really wrong” assertion. Broadly, we agree - I just wanted to write down the reasoning and nuances of that outcome. Cheers, Dan. — Dr Daniel Holmes PhD Architect (HPC Research) [email protected]<mailto:[email protected]> Phone: +44 (0) 131 651 3465 Mobile: +44 (0) 7940 524 088 Address: Room 2.09, Bayes Centre, 47 Potterrow, Central Area, Edinburgh, EH8 9BT — The University of Edinburgh is a charitable body, registered in Scotland, with registration number SC005336. — On 2 Nov 2019, at 09:13, Rolf Rabenseifner via mpiwg-large-counts <[email protected]<mailto:[email protected]>> wrote: After the Telcon it seems that this ticket is really wrong. Some or all of the routines may/should be kept. And it these routines arean essential part of the future large count concept. Thank you very much for pointing us to this ticket. Rolf ----- Jeff Hammond <[email protected]<mailto:[email protected]>> wrote: Rolf: Have you looked at https://github.com/mpiwg-large-count/large-count-issues/issues/6? Jeff On Fri, Nov 1, 2019 at 1:00 AM Rolf Rabenseifner <[email protected]<mailto:[email protected]>> wrote: A small comment on the result of our telcon: - Postfix _l for int -> MPI_Count - Postfix _x for additionally MPI_Aint -> MPI_Count I.e., the additional routines in the derived datatype chapter. Two of them already exist MPI_Type_get_(true)extent_x In Fortran we will have then for the same routine two aliases: - the overload one without _x - and the explicit one with _x For both ones, the internal function name is the same, with _x. Best regards Rolf ----- Jeff Hammond <[email protected]<mailto:[email protected]>> wrote: On Thu, Oct 31, 2019 at 7:48 AM Rolf Rabenseifner <[email protected]<mailto:[email protected]>> wrote: Dear all, here my summary as input for our telcon today. In principle, it is a very simple question: with large Counts, do we - keep all MPI_Aint - or do we substitute MPI_Aint by MPI_Count? I haven't been involved as much lately but did we not use MPI_Count for count and element displacements in the large count proposal? We need to use MPI_Aint for offsets into memory because that is what this type is for. Jeff In principle, the MPI Forum answered this question already for MPI-3.0 in 2012 with a clear YES: int MPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent) int MPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent) About Jeff H. question: If we limit the API to not support MPI_Count means that an MPI implementation has not really such quality options when using I/O fileviews, because the API is restricted to MPI_Aint (which should be implemented based on the, e.g., 64bit memory system). About Jim's comment: Apologies, it's been a while since I looked at the I/O interfaces. If I/O only needs relative displacements that have normal integer semantics, then I don't see why MPI_Count would not work for this purpose. If you have an MPI_Aint that contains a relative displacement, it also has normal integer semantics and can be converted to an MPI_Count. Yes, but this automatically implies that the datatypes must also be able to handle MPI_Count. The only case we really need to look out for is when an integer type contains an absolute address. In those cases, the quantity in the variable cannot be treated as a normal integer and we need special routines to work with it. Yes, this happens when we extend MPI_Aint in the derived datatype routines to MPI_Count. But in principle, this is not a big Problem, as you all could see in the previous emails: - We must do for MPI_Count the same as we did for MPI_Aint, i.e., we'll have long versions of the routines MPI_Get_address, MPI_Aint_diff, MPI_Aint_add - And we must ensure that the type cast from MPI_Aint to MPI_Count works, which is a small new advice to implementors for MPI_Det_address. Therefore again my 4 questions: - Should the new large count routines be prepared for more than 10 or 20 Exabyte files where we need 64/65 or or 65/66 unsigned/signed integers for relative byte displacements or byte counts? If yes, then all MPI_Aint arguments must be substituted by MPI_Count. (In other words, do we want to be prepared for another 25 years of MPI? :-) As stated above, the MPI-Forum already decided 2012 with a YES. - Should we allow that these new routines are also used for memory description, where we typically need only the large MPI_Count "count" arguments? (or should we provide two different new routines for each routine that currently has int Count/... and MPI_Aint disp/... arguments) I expect, that nobody wants to have two different large versions of for example MPI_Type_create_struct. - Should we allow a mix of old and new routines, especially for memory-based usage, that old-style MPI_Get_address is used to retrieve an absolute address and then, e.g., new style MPI_Type_create_struct with MPI_Count blocklength and displacements is used? I expect that forbidding such a mix would be a problem for Software development. Often old-style modules must work together with new-style modules. - Do we want to require for this type cast of MPI_Aint addr into MPI_Count that it is allowed to do this cast with a normal assignment, rather than a special MPI function? I expect yes, because for must usage of MPI_Aint and MPI_Count, it is for relative displacements or byte counts, i.e. for normal integers and therefore automatic type cast between MPI_Aint and MPI_Count is a must. With yes to all four questions, the proposed solution above is the easiest way. Hope to see/hear you today in our telcon. Best regards Rolf ----- Original Message ----- From: "Jeff Hammond" <[email protected]<mailto:[email protected]>> To: "mpiwg-large-counts" <[email protected]<mailto:[email protected]>> Cc: "Rolf Rabenseifner" <[email protected]<mailto:[email protected]>>, "Jim Dinan" < [email protected]<mailto:[email protected]>> Sent: Thursday, October 31, 2019 5:58:30 AM Subject: Re: [Mpiwg-large-counts] Large Count - the principles for counts, sizes, and byte and nonbyte displacements What if we just decided not to support IO displacements bigger than 2^63? What use case would that break? If the underlying filesystem uses 128b displacements, fine, then MPI will promote into those before using the system APIs. We already limit all sorts of things. For example, posting 17 billion Isends is not guaranteed to work. Maybe it does, but that's a quality of implementation issue. No sane person is going to have a data type spanning 8 exabyte increments. Not now, not in 2030, not in 2040, not ever. Jeff On Wed, Oct 30, 2019 at 9:10 AM Jim Dinan via mpiwg-large-counts < [email protected]<mailto:[email protected]>> wrote: Apologies, it's been a while since I looked at the I/O interfaces. If I/O only needs relative displacements that have normal integer semantics, then I don't see why MPI_Count would not work for this purpose. If you have an MPI_Aint that contains a relative displacement, it also has normal integer semantics and can be converted to an MPI_Count. The only case we really need to look out for is when an integer type contains an absolute address. In those cases, the quantity in the variable cannot be treated as a normal integer and we need special routines to work with it. If MPI never treats an MPI_Count quantity as an absolute address then MPI_Count should always have normal integer semantics via the MPI interfaces and doesn't need special treatment. Unless, of course, we want to enable MPI_Count that is large enough to need special support for basic operations, but that's a different can of worms. ~Jim. On Wed, Oct 30, 2019 at 11:02 AM Rolf Rabenseifner < [email protected]<mailto:[email protected]>> wrote: Dear Jim, This sounds to me like it is creating again the same problem we have with MPI_Aint --- one type doing too many things. If MPI_Aint can't accommodate absolute addresses in the I/O interfaces, I/O has no absolute addresses. Only relative one, i.e., byte displacements and byte sizes. But they can be huge. The same routines are used for message passing, for example - MPI_TYPE_CREATE_STRUCT or - MPI_TYPE_CREATE_RESIZED we should consider adding a new type like MPI_Faint (file address int) for this quantity and include accessor routines to ensure manipulations of file addresses respect the implementation defined meaning of the bits. Yes, you are right, there are two possibilities: Substitute MPI_Aint in the large count version by - MPI_Count or - or by a new type MPI_Laint (for Long Aint) Others on this list have already expressed that they never want to see such a MPI_Laint Even in C, it is not portable to do arithmetic on intptr_t because the integer representation of an address is implementation defined. We were careful in the definition of MPI_Aint_add and diff to describe them in terms of casting the absolute address arguments back to pointers before performing arithmetic. Yes, therefore, for this longer Version of MPI_Aint, let's name it for the Moment XXX, we Need MPI_XXX_diff and MPI_XXX_add, i.e. MPI_Laint_diff and _add or MPI_Count_diff and _add, which should be used only if the corresponding addresses are returned from MPI_Get_address_l. Or form MPI_Get_address, and with this we have again the type casting problem between MPI_Aint and MPI_Count or MPI_Laint. Best regards Rolf ----- Original Message ----- From: "Jim Dinan" <[email protected]<mailto:[email protected]>> To: "Rolf Rabenseifner" <[email protected]<mailto:[email protected]>> Cc: "mpiwg-large-counts" <[email protected]<mailto:[email protected]> Sent: Wednesday, October 30, 2019 3:45:01 PM Subject: Re: [Mpiwg-large-counts] Large Count - the principles for counts, sizes, and byte and nonbyte displacements This sounds to me like it is creating again the same problem we have with MPI_Aint --- one type doing too many things. If MPI_Aint can't accommodate absolute addresses in the I/O interfaces, we should consider adding a new type like MPI_Faint (file address int) for this quantity and include accessor routines to ensure manipulations of file addresses respect the implementation defined meaning of the bits. Even in C, it is not portable to do arithmetic on intptr_t because the integer representation of an address is implementation defined. We were careful in the definition of MPI_Aint_add and diff to describe them in terms of casting the absolute address arguments back to pointers before performing arithmetic. ~Jim. On Wed, Oct 30, 2019 at 5:18 AM Rolf Rabenseifner < [email protected]<mailto:[email protected]> wrote: Dear all and Jim, Jim asked: When you assign an MPI_Aint to an MPI_Count, there are two cases depending on what the bits in the MPI_Aint represent: absolute address and relative displacements. The case where you assign an address to a count doesn't make sense to me. Why would one do this and why should MPI support it? The case where you assign a displacement to a count seems fine, you would want sign extension to happen. The answer is very simple: All derived datatype routines serve describing of memory **and** file space. Therefore, the large count working group should decide: - Should the new large count routines be prepared for more than 10 or 20 Exabyte files where we need 64/65 or 65/66 unsigned/signed integers for relative byte displacements or byte counts? If yes, then all MPI_Aint arguments must be substituted by MPI_Count. (In other words, do we want to be prepared for another 25 years of MPI? :-) - Should we allow that these new routines are also used for memory description, where we typically need only the large MPI_Count "count" arguments? (or should we provide two different new routines for each routine that currently has int Count/... and MPI_Aint disp/... arguments) - Should we allow a mix of old and new routines, especially for memory-based usage, that old-style MPI_Get_address is used to retrieve an absolute address and then, e.g., new style MPI_Type_create_struct with MPI_Count blocklength and displacements is used? - Do we want to require for this type cast of MPI_Aint addr into MPI_Count that it is allowed to do this cast with a normal assignment, rather than a special MPI function? If we answer all four questions with yes (and in my opinion, we must) then Jim's question "Why would one do this [assign an address to a Count] and why should MPI support it?" is answered with this set of reasons. I would say, that this is the most complex decision that the large count working group has to decide. A wrong decision would be hard to be fixed in the future. Best regards Rolf ----- Original Message ----- From: "Jim Dinan" <[email protected]<mailto:[email protected]>> To: "Rolf Rabenseifner" <[email protected]<mailto:[email protected]>> Cc: "mpiwg-large-counts" < [email protected]<mailto:[email protected]>> Sent: Tuesday, October 29, 2019 10:28:46 PM Subject: Re: [Mpiwg-large-counts] Large Count - the principles for counts, sizes, and byte and nonbyte displacements If you do pointer arithmetic, the compiler will ensure that the result is correct. If you convert a pointer into an integer and then do the arithmetic, the compiler can't help you and the result is not portable. This is why MPI_Aint_add describes what it does in terms of pointer arithmetic. The confusing and frustrating thing about MPI_Aint is that it's one type for two very different purposes. Allowing direct +/- on MPI_Aint values that represent addresses is not portable and is a mistake that we tried to correct with MPI_Aint_add/diff (I am happy to strengthen should to must if needed). It's perfectly fine to do arithmetic on MPI_Aint values that are displacements. When you assign an MPI_Aint to an MPI_Count, there are two cases depending on what the bits in the MPI_Aint represent: absolute address and relative displacements. The case where you assign an address to a count doesn't make sense to me. Why would one do this and why should MPI support it? The case where you assign a displacement to a count seems fine, you would want sign extension to happen. ~Jim. On Tue, Oct 29, 2019 at 4:52 PM Rolf Rabenseifner < [email protected]<mailto:[email protected]>> wrote: Dear Jim, (a3) Section 4.1.5 of MPI 3.1 states "To ensure portability, arithmetic on absolute addresses should not be performed with the intrinsic operators \-" and \+". The major problem is, that we decided "should" and not "maust" or "shall", because there is such many existing MPI-1 ... MPI-3.0 code that must have used + or - operators. The only objective, that is true from the beginning, that MPI addresses must be retrieved with MPI_Get_address. And the second also Major Problem is the new assigment of an MPI_Aint value into an MPI_Count variable with MPI_Count larger than MPI_Aint. Therefore, I would prefere, that we keep this "should" and design in long term MPI_Get_address in a way that in principle MPI_Aint_diff and _add need not to do anythin else as the + or - operator. And this depends on the meaning of the unsigned addresses, i.e., what is the sequence of addresses (i.e., is it really going from 0 to FFFF...FFFF) and than mapping these addreses to the mathematical sequence of MPI_Aint which starts at -2**(n-1) and ends at 2**(n-1)-1. Thats all. For the moment, as far as the web and some emails told us, we are fare away from this contiguous 64-bit address space (0 to FFFF...FFFF). But we should be correctly prepared. Or in other words: (a2) Should be solved by MPI_Aint_add/diff. In my opinion no, it must be solved by MPI_Get_addr and MPI_Aint_add/diff can stay normal + or - operators. I should also mention, that of course all MPI routines that accept MPI_BOOTOM must reverse the work of MPI_Get_address to get back the real "unsigned" virtual addresses of the OS. The same what we already had if an implementation has chosen to use the address of an MPI common block as base for MPI_BOTTOM. Here, the MPI lib had the freedom to revert the mapping within MPI_Get_addr or within all functions called with MPI_BOTTOM. Best regards Rolf ----- Original Message ----- From: "Jim Dinan" <[email protected]<mailto:[email protected]>> To: "Rolf Rabenseifner" <[email protected]<mailto:[email protected]>> Cc: "mpiwg-large-counts" < [email protected]<mailto:[email protected]>> Sent: Tuesday, October 29, 2019 3:58:18 PM Subject: Re: [Mpiwg-large-counts] Large Count - the principles for counts, sizes, and byte and nonbyte displacements Hi Rolf, (a1) seems to me like another artifact of storing an unsigned quantity in a signed variable, i.e., the quantity in an MPI_Aint can be an unsigned address or a signed displacement. Since we don't have an unsigned type for addresses, the user can't portably fix this above MPI. We will need to add functions to deal with combinations of MPI_Aint and MPI_Counts. This is essentially why we needed MPI_Aint_add/diff. Or ... the golden (Au is gold) int ... MPI_Auint. (a2) Should be solved by MPI_Aint_add/diff. (a3) Section 4.1.5 of MPI 3.1 states "To ensure portability, arithmetic on absolute addresses should not be performed with the intrinsic operators \-" and \+". MPI_Aint_add was written carefully to indicate that the "base" argument is treated as an unsigned address and the "disp" argument is treated as a signed displacement. ~Jim. On Tue, Oct 29, 2019 at 5:19 AM Rolf Rabenseifner < [email protected]<mailto:[email protected]>> wrote: Dear Jim and all, I'm not sure whether I'm really able to understand your email. I take the MPI view: (1) An absolute address can stored in an MPI_Aint variable with and only with MPI_Get_address or MPI_Aint_add. (2) A positive or negative number of bytes or a relative address which is by definition the amount of bytes between two locations in a MPI "sequential storage" (MPI-3.1 page 115) can be assigned with any method to an MPI_Aint variable as long as the original value fits into MPI_Aint. In both languages automatic type cast (i.e., sign expansion) is done. (3) If users misuse MPI_Aint for storing anything else into MPI_Aint variable then this is out of scope of MPI. If such values are used in a minus operation then it is out of the scope of MPI whether this makes sense. If the user is sure that the new value falls into category (2) then all is fine as long as the user is correct. I expect that your => is not a "greater or equal than". I expect that you noticed assignments. intptr_t => MPI_Aint "intptr_t: integer type capable of holding a pointer." uintptr_t => ??? (Anyone remember the MPI_Auint "golden Aint" proposal?) "uintptr_t: unsigned integer type capable of holding a pointer." may fall exactly exactly into (3) when used for pointers. Especially on a 64 bit system the user may have in the future exactly the problems (a), (a1), (a2) and (b) as described below. But here, the user is responsible, to for example implement (a3), whereas for MPI_Get_address, the implementors of the MPI library are responsible and the MPI Forum may be responsible for giving the correct advices. By the way, the golden MPI_Auint was never golden. Such need was "resolved" by introducing MPI_Aint_diff and MPI_Aint_add in MPI-3.1. ptrdiff_t => MPI_Aint "std::ptrdiff_t is the signed integer type of the result of subtracting two pointers." may perfectly fit to (2). All of the following falls into category (2): size_t (sizeof) => MPI_Count, int "sizeof( type ) (1) sizeof expression (2) Both versions are constant expressions of type std::size_t." size_t (offsetof) => MPI_Aint, int "Defined in header <cstddef> #define offsetof(type, member) /*implementation-defined*/ The macro offsetof expands to an integral constant expression of type std::size_t, the value of which is the offset, in bytes, from the beginning of an object of specified type to ist specified member, including padding if any." Note that this offsetof has nothing to do with MPI_Offset. On a system with less than 2*31 byte and 4-byte int, it is guaranteed that size_t => int works. On a system with less than 2*63 byte and 8-byte MPI_Aint, it is guaranteed that size_t => MPI_Aint works. Problem: size_t is unsigned, int and MPI_Aint are signed. MPI_Count should be defined in a way that on systems with more than 2**63 Bytes of disc space, that MPI_Count can hold such values, because int .LE. {MPI_Aint, MPI_Offset} .LE. MPI_Count Therefore size_t => MPI_Count should always work. ssize_t => Mostly for error handling. Out of scope for MPI? "In short, ssize_t is the same as size_t, but is a signed type - read ssize_t as “signed size_t”. ssize_t is able to represent the number -1, which is returned by several system calls and library functions as a way to indicate error. For example, the read and write system calls: ... ssize_t read(int fildes, void *buf, size_t nbyte); ..." ssize_t fits therefore better to MPI_Aint, because both are signed types that can hold byte counts, but the value -1 in a MPI_Aint variable stands for a byte displacement of -1 bytes and not for an error code -1. All use of (2) is in principle no problem. ------------------------------------------ All the complex discussiuon of the last days is about (1): (1) An absolute address can stored in an MPI_Aint variable with and only with MPI_Get_address or MPI_Aint_add. In MPI-1 to MPI-3.0 and still in MPI-3.1 (here as may be not portable), we also allow MPI_Aint variable := absolute address in MPI_Aint variable + or - a number of bytes (in any integer type). The result is then still in category (1). For the difference of two absolute addresses, MPI_Aint_diff can be used. The result is than MPI_Aint of category (2) In MPI-1 to MPI-3.0 and still in MPI-3.1 (here as may be not portable), we also allow MPI_Aint variable := absolute address in MPI_Aint variable - absolute address in MPI_Aint variable. The result is then in category (2). The problems we discuss the last days are about systems that internally use unsigned addresses and the MPI library stores these addresses into MPI_Aint variables and (a) a sequential storage can have virtual addresses that are both in the area with highest bit =0 and other addresses in the same sequential storage (i.e., same array or structure) with highest bit =1. or (b) some higher bits contain segment addresses. (b) is not a problem as long as a sequential storage resides always within one Segment. Therefore, we only have to discuss (a). The two problems that we have is (a1) that for the minus operations an integer overflow will happen and must be ignored. (a2) if such addresses are expanded to larger variables, e.g., MPI_Count with more bits in MPI_Count than in MPI_Aint, sign expansion will result in completely wring results. And here, the most simple trick is, (a3) that MPI_Get_address really shall map the contiguous unsigned range from 0 to 2**64-1 to the signed (and also contiguous) range from -2**63 to 2**63-1 by simple subtracting 2**63. With this simple trick in MPI_Get_address, Problems 8a1) and (a2) are resolved. It looks like that (a) and therefore (a1) and (a2) may be far in the future. But they may be less far in the future, if a system may map the whole applications cluster address space into virtual memory (not cache coherent, but accessible). And all this is never or only partial written into the MPI Standard, also all is (well) known by the MPI Forum, with the following exceptions: - (a2) is new. - (a1) is solved in MPI-3.1 only for MPI_Aint_diff and MPI_Aint_add, but not for the operators - and + if a user will switch on integer overflow detection in the future when we will have such large systems. - (a3) is new and in principle solves the problem also for + and - operators. At lease (a1)+(a2) should be added as rationale to MPI-4.0 and (a3) as advice to implementors within the framework of big count, because (a2) is newly coming with big count. I hope this helps a bit if you took the time to read this long email. Best regards Rolf ----- Original Message ----- From: "mpiwg-large-counts" < [email protected]<mailto:[email protected]> To: "mpiwg-large-counts" < [email protected]<mailto:[email protected]>> Cc: "Jim Dinan" <[email protected]<mailto:[email protected]>>, "James Dinan" < [email protected]<mailto:[email protected]>> Sent: Monday, October 28, 2019 5:07:37 PM Subject: Re: [Mpiwg-large-counts] Large Count - the principles for counts, sizes, and byte and nonbyte displacements Still not sure I see the issue. MPI's memory-related integers should map to types that serve the same function in C. If the base language is broken for segmented addressing, we won't be able to fix it in a library. Looking at the mapping below, I don't see where we would have broken it: intptr_t => MPI_Aint uintptr_t => ??? (Anyone remember the MPI_Auint "golden Aint" proposal?) ptrdiff_t => MPI_Aint size_t (sizeof) => MPI_Count, int size_t (offsetof) => MPI_Aint, int ssize_t => Mostly for error handling. Out of scope for MPI? It sounds like there are some places where we used MPI_Aint in place of size_t for sizes. Not great, but MPI_Aint already needs to be at least as large as size_t, so this seems benign. ~Jim. On Fri, Oct 25, 2019 at 8:25 PM Dinan, James via mpiwg-large-counts < [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] > wrote: Jeff, thanks so much for opening up these old wounds. I’m not sure I have enough context to contribute to the discussion. Where can I read up on the issue with MPI_Aint? I’m glad to hear that C signed integers will finally have a well-defined representation. ~Jim. From: Jeff Hammond < [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] Date: Thursday, October 24, 2019 at 7:03 PM To: "Jeff Squyres (jsquyres)" < [ mailto: [email protected]<mailto:[email protected]> | [email protected]<mailto:[email protected]> ] > Cc: MPI BigCount Working Group < [ mailto: [email protected] | [email protected] ] >, "Dinan, James" < [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] Subject: Re: [Mpiwg-large-counts] Large Count - the principles for counts, sizes, and byte and nonbyte displacements Jim (cc) suffered the most in MPI 3.0 days because of AINT_DIFF and AINT_SUM, so maybe he wants to create this ticket. Jeff On Thu, Oct 24, 2019 at 2:41 PM Jeff Squyres (jsquyres) < [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] > wrote: Not opposed to ditching segmented addressing at all. We'd need a ticket for this ASAP, though. This whole conversation is predicated on: - MPI supposedly supports segmented addressing - MPI_Aint is not sufficient for modern segmented addressing (i.e., representing an address that may not be in main RAM and is not mapped in to the current process' linear address space) If we no longer care about segmented addressing, that makes a whole bunch of BigCount stuff a LOT easier. E.g., MPI_Aint can basically be a non-segment-supporting address integer. AINT_DIFF and AINT_SUM can go away, too. On Oct 24, 2019, at 5:35 PM, Jeff Hammond via mpiwg-large-counts < [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] > wrote: Rolf: Before anybody spends any time analyzing how we handle segmented addressing, I want you to provide an example of a platform where this is relevant. What system can you boot today that needs this and what MPI libraries have expressed an interest in supporting it? For anyone who didn't hear, ISO C and C++ have finally committed to twos-complement integers ( [ http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2018/p0907r1.html | http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2018/p0907r1.html ] , [ http://www.open-std.org/jtc1/sc22/wg14/www/docs/n2218.htm | http://www.open-std.org/jtc1/sc22/wg14/www/docs/n2218.htm ] ) because modern programmers should not be limited by hardware designs from the 1960s. We should similarly not waste our time on obsolete features like segmentation. Jeff On Thu, Oct 24, 2019 at 10:13 AM Rolf Rabenseifner via mpiwg-large-counts < [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] > wrote: I think that changes the conversation entirely, right? Not the first part, the state-of-current-MPI. It may change something for the future, or a new interface may be needed. Please, can you describe how MPI_Get_address can work with the different variables from different memory segments. Or whether a completely new function or a set of functions is needed. If we can still express variables from all memory segments as input to MPI_Get_address, there may be still a way to flatten the result of some internal address-iquiry into a flattened signed integer with the same behavior as MPI_Aint today. If this is impossible, then new way of thinking and solution may be needed. I really want to see examples for all current stuff as you mentioned in your last email. Best regards Rolf ----- Original Message ----- From: "Jeff Squyres" < [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] > To: "Rolf Rabenseifner" < [ mailto: [email protected]<mailto:[email protected]> | [email protected]<mailto:[email protected]> ] Cc: "mpiwg-large-counts" < [ mailto: [email protected]<mailto:[email protected]> | [email protected]<mailto:[email protected]> ] > Sent: Thursday, October 24, 2019 5:27:31 PM Subject: Re: [Mpiwg-large-counts] Large Count - the principles for counts, sizes, and byte and nonbyte displacements On Oct 24, 2019, at 11:15 AM, Rolf Rabenseifner < [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] <mailto: [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] wrote: For me, it looked like that there was some misunderstanding of the concept that absolute and relative addresses and number of bytes that can be stored in MPI_Aint. ...with the caveat that MPI_Aint -- as it is right now -- does not support modern segmented memory systems (i.e., where you need more than a small number of bits to indicate the segment where the memory lives). I think that changes the conversation entirely, right? -- Jeff Squyres [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] <mailto: [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] > -- Dr. Rolf Rabenseifner . . . . . . . . . .. email [ mailto: [email protected]<mailto:[email protected]> | [email protected]<mailto:[email protected]> ] . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . [ http://www.hlrs.de/people/rabenseifner | www.hlrs.de/people/rabenseifner<http://www.hlrs.de/people/rabenseifner> ] . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . _______________________________________________ mpiwg-large-counts mailing list [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] [ https://lists.mpi-forum.org/mailman/listinfo/mpiwg-large-counts | https://lists.mpi-forum.org/mailman/listinfo/mpiwg-large-counts ] -- Jeff Hammond [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] [ http://jeffhammond.github.io/ | http://jeffhammond.github.io/ ] _______________________________________________ mpiwg-large-counts mailing list [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] [ https://lists.mpi-forum.org/mailman/listinfo/mpiwg-large-counts | https://lists.mpi-forum.org/mailman/listinfo/mpiwg-large-counts ] -- Jeff Squyres [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] -- Jeff Hammond [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] [ http://jeffhammond.github.io/ | http://jeffhammond.github.io/ ] _______________________________________________ mpiwg-large-counts mailing list [ mailto:[email protected] | [email protected]<mailto:[email protected]> ] [ https://lists.mpi-forum.org/mailman/listinfo/mpiwg-large-counts | https://lists.mpi-forum.org/mailman/listinfo/mpiwg-large-counts ] _______________________________________________ mpiwg-large-counts mailing list [email protected]<mailto:[email protected]> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-large-counts -- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected]<mailto:[email protected]> . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner<http://www.hlrs.de/people/rabenseifner> . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . -- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected]<mailto:[email protected]> . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner<http://www.hlrs.de/people/rabenseifner> . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . -- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected]<mailto:[email protected]> . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner<http://www.hlrs.de/people/rabenseifner> . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . -- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected]<mailto:[email protected]> . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner<http://www.hlrs.de/people/rabenseifner> . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . _______________________________________________ mpiwg-large-counts mailing list [email protected]<mailto:[email protected]> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-large-counts -- Jeff Hammond [email protected]<mailto:[email protected]> http://jeffhammond.github.io/ -- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected]<mailto:[email protected]> . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner<http://www.hlrs.de/people/rabenseifner> . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . -- Jeff Hammond [email protected]<mailto:[email protected]> http://jeffhammond.github.io/ -- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected]<mailto:[email protected]> . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner<http://www.hlrs.de/people/rabenseifner> . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . -- Jeff Hammond [email protected]<mailto:[email protected]> http://jeffhammond.github.io/ -- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected]<mailto:[email protected]> . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner<http://www.hlrs.de/people/rabenseifner> . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . _______________________________________________ mpiwg-large-counts mailing list [email protected]<mailto:[email protected]> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-large-counts _______________________________________________ mpiwg-large-counts mailing list [email protected]<mailto:[email protected]> https://lists.mpi-forum.org/mailman/listinfo/mpiwg-large-counts -- Jeff Squyres [email protected]<mailto:[email protected]>
participants (1)
