Re: [Mpi3-hybridpm] [EXTERNAL] Re: Threading homeworking / next telecon
You'll have to explain in person because I still don't see why the following doesn't work. int MPIX_Comm_split_inherit_info(MPI_Comm comm, int color, int key, MPI_Comm * newcomm) { /* assuming MPI_ERRORS_ARE_FATAL... */ MPI_Info info; MPI_Comm_get_info(comm, &info); MPI_Comm_split(comm, color, key, newcomm); MPI_Comm_set_info(*newcomm, info); MPI_Info_free(&info); return MPI_SUCCESS; } I did not bother to implement attribute copying because I don't understand how those work yet and because I am in favor of using MPI_Info to tell the implementation about communicator team progress anyways. Best, Jeff On Mon, Mar 25, 2013 at 9:56 PM, Pavan Balaji <[email protected]> wrote:
Jeff,
One of the goals of the original proposal was to use this in an MPI+UPC environment. If there was inheritance, the UPC runtime could dup COMM_WORLD as many times as there are UPC threads and just hand them to each thread as a new "COMM_WORLD", say upc_comm[] (each element of this array would be a comm specific to a UPC thread). Without inheritance, this becomes tricky since each new communicator creation has to be tracked and setup explicitly using Comm_set_info. This is especially hard when you have stacked libraries.
I can explain in person why we rejected this model, if it's still not clear.
-- Pavan
On 03/25/2013 09:29 PM US Central Time, Jeff Hammond wrote:
Hi Pavan,
I am confused why one cannot use MPI_Comm_get_info+MPI_Comm_set_info to inherit this information. I found http://meetings.mpi-forum.org/secretary/2012/12/slides/mpi31-hybrid.pptx online and it seems that there is some issue with this method but I cannot determine it from the slides. Can you elaborate on what is the problem with this approach?
Jeff
On Mon, Mar 25, 2013 at 8:19 PM, Pavan Balaji <[email protected]> wrote:
I guess you could do that. In our case, it was still not helpful as we needed the inheritance to be automatic, once an upper-layer (such as UPC) passes a 'comm' as an alternative to MPI_COMM_WORLD.
-- Pavan
On 03/25/2013 07:47 PM US Central Time, Jeff Hammond wrote:
Could the MPI_Info kv-pair not associate a communicator with a collection of communicators upon which progress was made simultaneously? If the key is "communicator team" and the value is an integer indexing said teams, can one not create such groups?
Jeff
On Mon, Mar 25, 2013 at 7:41 PM, Pavan Balaji <[email protected]> wrote:
The problem was that this wasn't allow us to create a group of communicators on which progress is made. Each communicator was independent of everything else.
However, our goal was allowing each "UPC thread" to be an MPI rank, where all threads share that rank. Your goal is different, so this might or might not be a concern for you.
-- Pavan
On 03/25/2013 07:39 PM US Central Time, Jeff Hammond wrote:
Why can't a user do MPI_COMM_SET_INFO explicitly every time they want per-communicator semantics?
Jeff
On Mon, Mar 25, 2013 at 7:30 PM, Pavan Balaji <[email protected]> wrote:
FWIW, we discussed a similar in the hybrid WG a few meetings ago. The main reason why we didn't go down that path was because per-communicator semantics are not fully inherited for child communicators. For example, split does not inherit info arguments or communicator attributes, while dup does.
-- Pavan
On 03/25/2013 05:31 PM US Central Time, Sur, Sayantan wrote:
This is interesting. It might be useful for implementers if the app could inform the MPI library that in its usage model, per-communicator queues might lead to a performance benefit. Such as in the case of many threads (among others).
Info key? Assert?
Sayantan
*From:*[email protected] [mailto:[email protected]] *On Behalf Of *William Gropp *Sent:* Monday, March 25, 2013 2:24 PM *To:* [email protected] *Subject:* Re: [Mpi3-hybridpm] [EXTERNAL] Re: Threading homeworking / next telecon
An implementation is free to use separate queues for each communicator; some of us have discussed this in the past, in part to permit use of lock-free structures for the queue updates, particularly as this is the only place there are no wild cards, ever. I believe that this is within the existing semantics. It even has benefits for single threaded execution, since the communicator matching is done once, rather than in every query on the queue.
In terms of progress, the standard is deliberately vague on the details, and thus I don't believe we have the requirement that you quote. And some of the other interpretations of progress would not be helped by any thread-safety restriction.
Bill
William Gropp
Director, Parallel Computing Institute
Deputy Director for Research
Institute for Advanced Computing Applications and Technologies
Thomas M. Siebel Chair in Computer Science
University of Illinois Urbana-Champaign
On Mar 25, 2013, at 4:15 PM, Jeff Hammond wrote:
On Mon, Mar 25, 2013 at 3:17 PM, William Gropp <[email protected] <mailto:[email protected]>> wrote:
I was only addressing the issue of calling the thread level routines before
knowing what thread level you had.
Okay, sorry, I cannot tell which tickets people are referring to since I have a bunch of different ones right now.
I'm not sure what you are looking for. In the case of MPI_THREAD_MULTIPLE,
an implementation can provide significant concurrency today without any
change in the MPI standard - that's a major reason for that table (more to
the point - this table is meant as a guide for not using locks). Can you
give me an example of something that the current MPI semantics prohibits
that you'd like to achieve with MPI_THREAD_PER_OBJECT?
It is my understanding of the progress requirements that any call to MPI must make progress on all MPI operations. This means that two threads calling e.g. MPI_Recv must walk all of the message queues. If a thread needs to modify any queue because it matches, then this must be done in a thread-safe way, which presumably requires something resembling mutual exclusion or transactions. If a call to MPI_Recv only had to make progress on its own communicator, then two threads calling MPI_Recv on two different communicators would (1) only have to walk the message queue associated with that communicator and (2) nothing resembling mutual exclusion is required for the thread to update the message queue in the event that matching occurs.
Forgive me if I've got some of the details wrong. If I've got all of the details and the big picture wrong, then I'll think about it more.
Jeff
On Mar 25, 2013, at 2:53 PM, Jeff Hammond wrote:
That doesn't do much for me in terms of enabling greater concurrency
in performance-critical operations.
I'd like to propose that we try to make all of "Access Only", "Update
RefCount", "Read of List" and "None" thread safe in all cases. All of
these are read-only except for "Update RefCount", but this can be done
with atomics. I am assuming that concurrent reads are only permitted
to happen after the writing calls on the object have completed. This
is the essence of MPI_THREAD_PER_OBJECT.
Jeff
Mpi3-hybridpm mailing list
http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-hybridpm
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] <mailto:[email protected]> / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond _______________________________________________ Mpi3-hybridpm mailing list [email protected] <mailto:[email protected]> http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-hybridpm
_______________________________________________ Mpi3-hybridpm mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-hybridpm
-- Pavan Balaji http://www.mcs.anl.gov/~balaji _______________________________________________ Mpi3-hybridpm mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-hybridpm
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
participants (1)
Jeff Hammond
