Re: [Mpi3-hybridpm] Ticket 217 proposal document updated
Hi Doug, Thanks for the quick response -- and for correcting my poor OpenMP. I think that DIM was just meant to have the amount of work not depend on COUNT. Either way should be fine. In terms of the info argument, I would prefer an example without it where the caption states that "nobreak" could be used. I think we had this and it didn't work well at the Forum, so maybe it is logistically better to keep it. If we can get rid of the barrier, I think the example would be clearer. ~Jim. On 1/30/12 2:55 PM, Douglas Miller wrote:
Yes, the idea about the for loop at the bottom was that a parallel copy is faster. Yes, it eliminates the need for any additional synchronization. I guess it's about lines of code, I guess it could be "memcpy(...); #pragma omp barrier" but it seems like this way provokes more thinking about parallelism.
Re: "i" being private: in the "#pragma omp for" construct the loop-control variable is implicitly made private by OpenMP.
Re: "oldval = newval" having races: there is only one value for "newval", so each thread will redundantly copy the same value over the first thread's copy. the value is safe since no thread can update newval until all threads have completed the for loop. No thread can test the value(s) until all threads have completed not only the MPI_Team_leave but also the "for" loop that copies the array. Making them private complicates the example by requiring more synchronization in order to share/compute the single value between all threads.
Re: remove INFO "nobreak": my take from previous readings is that this was needed in the example. I am reluctant to remove it and face another set-back.
Q: What is "DIM" in the work for-loop? should that be "count" (COUNT) - the size of the sendbuf array? I've changed it to COUNT and ran a compile. Aside from no declaration for "i" it was fine. I added "i" inside the while loop, which eliminates concerns about a problem if shared.
Here's what I currently have for the example:
MPI_Team team; MPI_Info info; double oldval = 0.0, newval = 9.9e99; double tolerance = 1.0e-6; double sendbuf[COUNT] = { 0.0 }; double recvbuf[COUNT] = { 0.0 }; MPI_Info_create(&info); MPI_Info_set(info, "nobreak", "true"); MPI_Team_create(omp_get_thread_limit(), info, &team); MPI_Info_free(&info); #pragma omp parallel num_threads(omp_get_thread_limit()) { while (abs(newval - oldval) > tolerance) { double myval = 0.0; int i; oldval = newval;
# pragma omp for for (i = 0; i < COUNT; i++) { myval += do_work(i, sendbuf); }
# pragma omp critical { newval += myval; }
MPI_Team_join(omp_get_num_threads(), team); /* this barrier is not required but helps ensure * all threads arrive before the MPI_Allreduce begins */ # pragma omp barrier # pragma omp master { MPI_Allreduce(sendbuf, recvbuf, COUNT, MPI_DOUBLE, MPI_SUM, MPI_COMM_WORLD); } /* The remaining threads directly go to MPI_Team_leave */ MPI_Team_leave(team);
# pragma omp for for (i = 0; i < COUNT; i++) { sendbuf[i] = recvbuf[i]; } } } MPI_Team_free(&team);
_______________________________________________ Douglas Miller BlueGene Messaging Development IBM Corp., Rochester, MN USA Bldg 030-2 A401 [email protected] Douglas Miller/Rochester/IBM
Inactive hide details for Jim Dinan ---01/30/2012 01:58:19 PM---Jim Dinan <[email protected]>Jim Dinan ---01/30/2012 01:58:19 PM---Jim Dinan <[email protected]>
*Jim Dinan <[email protected]>* Sent by: [email protected]
01/30/2012 01:56 PM Please respond to [email protected]
To
cc
Subject
Hi Doug,
I think we can probably get rid of the barrier, it seems to suggest a stronger requirement (sync-first) for helper threads. MPI could implement this behavior internally in leave if it's required by the implementation.
This copy code also seems a bit verbose to me:
# pragma omp for for (i = 0; i < count; i++) { sendbuf[i] = recvbuf[i]; }
Is the idea that this would be faster than a serial memcpy? We could simplify the example by just calling memcpy. I guess we would need to add a barrier, though.
"i" needs to be made thread private (declare in parallel region?).
"double myval = 0.0" should be moved to the top of the block for C89 compliance.
oldval and newval are shared, "oldval = newval" will have race/consistency problems. Should these also be thread private?
"nobreak" adds a lot of lines of code and not a lot of information to the example. I think it would be better to point out in a caption that you could pass the "nobreak" info key and shorten the example by leaving out all the Info wrangling code.
Suggest s/count/COUNT/ so that it looks like a constant in the array declarations.
Have you tried compiling/running this with no-op/barrier implementations of the helper threads functions?
~Jim.
On 1/30/12 1:32 PM, Douglas Miller wrote:
The "#pragma omp for" does a barrier at the end of the block (since we did not specify "nowait"), so I don't think it is required.
Inactive hide details for Jim Dinan ---01/30/2012 12:44:47 PM---Jim Dinan <[email protected]>Jim Dinan ---01/30/2012 12:44:47 PM---Jim Dinan <[email protected]>
01/30/2012 12:38 PM Please respond to [email protected]
To
cc
Subject
Hi Doug,
In Example 12.3, the "#omp barrier" should be required to ensure that all threads have finished updating sendbuf and reading recvbuf before the Allreduce.
~Jim.
On 1/30/12 8:27 AM, Douglas Miller wrote:
I've updated the PDF in Ticket 217 based on latest comments. Please review the text and send me comments. This is an attempt to make the concept easier to follow by describing in terms of a "team epoch".
thanks, _______________________________________________ Douglas Miller BlueGene Messaging Development IBM Corp., Rochester, MN USA Bldg 030-2 A401 [email protected] Douglas Miller/Rochester/IBM
_______________________________________________ Mpi3-hybridpm mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-hybridpm
participants (1)
Jim Dinan
