Hi Dan, Benson, HACC-wg, The paper I referred to in the virtual meeting was the Euro-MPI'20 paper about MPI_Detach: https://dl.acm.org/doi/abs/10.1145/3416315.3416323 In the paper we also sketch, how continuations can be used to implement C++ code like: https://github.com/mpi-forum/mpi-issues/issues/288#issuecomment-619053687 The Cholesky code with MPI_Detach aka Continuation: The communication task in https://github.com/RWTH-HPC/cholesky_omptasks/blob/mpi-detach/detach-deps/ch... finishes execution immediately after calling MPI_Detach in https://github.com/RWTH-HPC/cholesky_omptasks/blob/mpi-detach/detach-deps/ch... Because of the detach clause on the task (OpenMP 5.0 feature), the task only completes, when the callback is called. Releasing the task dependencies depends on task completion. Effectively, this allows to span task dependence graphs across MPI ranks. A copy of my implementation of MPI_Detach as a wrapper (detach.cpp) is next to this file. If you want to try and run the code, make sure to export MPIX_DETACH=progress, so that the wrapper starts the progress thread. The Cholesky code without detach: The communication task explicitly waits on completion of the MPI communication: https://github.com/RWTH-HPC/cholesky_omptasks/blob/mpi-detach/fine-deps/ch_o... in this wait function: https://github.com/RWTH-HPC/cholesky_omptasks/blob/mpi-detach/fine-deps/ch_o... Implemented in here: https://github.com/RWTH-HPC/cholesky_omptasks/blob/mpi-detach/fine-deps/ch_c... The taskyield allows other tasks to get scheduled while waiting the MPI communication to complete. Unfortunately, the OpenMP semantics of taskyield are as weak as the progress guarantees from the MPI side ;) As a result, this code can deadlock, if too many communication tasks are created and only the OMPSS runtime can actually avoid the deadlock. The other versions of the code reduce the possible concurrency more and more, avoiding deadlocks, but increasing the execution time. Just recently, I did an extended performance analysis of the code, which shows that the overhead for the detach version displayed in the paper is purely a result of increasing data transfer with increasing number of nodes, amplified by the reduced amount of work per rank due to strong scaling. I.e., at some point there is not enough work available to overlap communication. Best Joachim -- Dr. rer. nat. Joachim Protze IT Center Group: High Performance Computing Division: Computational Science and Engineering RWTH Aachen University Seffenter Weg 23 D 52074 Aachen (Germany) Tel: +49 241 80- 24765 Fax: +49 241 80-624765 [email protected] www.itc.rwth-aachen.de
participants (1)
Joachim Protze
