Re: [Mpi3-hybridpm] endpoint proposal
Hi everybody, After some offline discussion w/ Pavan, it appears to me that we may not be understanding each other. I'll try to find time and show up at the next WG meeting to discuss with you the following points that in my opinion indicate that the endpoint and the helper thread proposals may need a closer joint consideration if not an outright merge: 1. A good threading runtime will know w/o a hint when to hijack the idle user threads for the internal use by the MPI library. Note that this admittedly implies that both the user application and the MPI implementation use the same threading runtime. This may and often is not the case. 2. An assumption that one set of calls will work to pass the hint to the MPI library again assumes that both use the same underlying threading runtime. I.e., this interface will effectively force a threading runtime unification, which may or may not be feasible. 3. The formulation of the helper thread proposal may need to be simplified by eliminating the teams and extending one extra call from the endpoint proposal by a few arguments, or adding 2 more calls to describe the desired thread state transition instead of the total of 7 in both proposals now. The essence of the latter is like this: If I were writing a naive interface that toggles thread state between (not visible to the MPI) - (associated with an endpoint and doing user's MPI work) - (doing some work inside the MPI implementation), I'd probably have but one call with a constant for this, like: int MPI_Thread_state(int state,...) where state is: MPI_THREAD_UNBOUND // thread has no MPI relation MPI_THREAD_ENDPOINT // thread is attached to an MPI endpoint. Vararg contains the endpoint to bind the thread to. MPI_THREAD_INTERNAL // thread is used by the MPI internally Alternatively, I'd have at most 3 calls to represent the required state transition: MPI_Thread_attach_internal MPI_Thread_attach_endpoint MPI_Thread_detach Currently, the endpoint proposal seems to have one call to enter the resp. state (MPI_Thread_attach == MPI_Thread_attach_endpoint) and no exit call. The helper thread proposal describes no less than 6 calls - enter, exit, and some while inside. Why? Do we really need the thread teams and the overhead related to managing them? I'm not sure we do. Why not having just 3 calls instead of 7? If this is a gross misunderstanding of both proposals on my part, please let me know. Best regards. Alexander -----Original Message----- From: Supalov, Alexander Sent: Tuesday, October 25, 2011 1:16 AM To: 'Pavan Balaji' Cc: [email protected] Subject: RE: [Mpi3-hybridpm] endpoint proposal Well, I did explain this. But since you've considered this matter already, and they will be merged in one chapter anyway, that's fine. -----Original Message----- From: Pavan Balaji [mailto:[email protected]] Sent: Tuesday, October 25, 2011 12:27 AM To: Supalov, Alexander Cc: [email protected] Subject: Re: [Mpi3-hybridpm] endpoint proposal Alexander, We have discussed these two proposals and how they interact with each other several times in the working group. We don't believe any changes are required in either proposal for them to work together. Also, either proposal would work without the other proposal. So they are, in fact, orthogonal. With respect to merging the two proposals, there is no good reason to. You did not explain why one proposal depends on the other. If there is no dependency, merging is not required. -- Pavan On 10/24/2011 04:53 PM, Supalov, Alexander wrote:
Thanks. I don't think they are orthogonal.
They are mutually exclusive as far as the resulting thread states are concerned. You may have:
0 (thread has no MPI involvement at all) A (thread is used as a helper thread by the MPI implementation) B (thread is used MPI by the MPI user in association w/ some endpoint)
And there's no AB (both helper and user thread w/ MPI). So, B above is actually -A.
Thus, the proposals will have to deal with the transitions 0A, A0, 0(-A),-A0, and most interestingly, -AA and A(-A).
Basing on this, it may be necessary to consider them together and make reciprocal adjustments in both documents.
The means of achieving the states A and -A may indeed appear orthogonal at the moment. I'd argue the closer they look, the better off we'll be. The helper thread proposal looks very rich on the ways to cut the cake. The endpoint proposal looks rather minimalistic. Would the helper thread proposal profit from some simplification? After all, you're "only" giving a thread on loan to the MPI. This should be doable with 1 call, maximum 2 (in and out).
I can even imagine that the THREAD_JOIN might look like (join user MPI space w/ assoc. endpoint) and (join MPI implementation space). Then the means would not be orthogonal either, reflecting the mutual exclusivity of the resp. states. This would arguably be a better design.
If the above makes sense, we'd rather merge the proposals.
-----Original Message----- From: Pavan Balaji [mailto:[email protected]] Sent: Monday, October 24, 2011 5:03 PM To: [email protected] Cc: Supalov, Alexander Subject: Re: [Mpi3-hybridpm] endpoint proposal
Alexander,
These are orthogonal concepts. Users can certainly use them together, but there is no reason to merge them.
-- Pavan
On 10/24/2011 05:25 AM, Supalov, Alexander wrote:
Thanks. Has someone tried to look into #217 (helper threads) and #284 (endpoints) with the view on merging them? After all, threads attaching to the endpoints are almost, but not quite unlike helper threads given on "loan" to the MPI implementation. In the first case, the application is using the threads by itself. In the second case, the MPI is using threads for internal purposes. See the analogy? In both cases we let threads use or be used by MPI. Is this something one could possibly unite? They are being placed like on different sides of the boundary:
Endpoints (#284):
Application threads Endpoints Communication resources
Helper threads (#217):
[Endpoints] Internal threads Communication resources
So, if we merge the pictures:
Application threads Endpoints (#284) Internal threads (#217) Communication resources
And what the unification would do is provide a way to convert the application threads into the internal threads and back. May be orthogonal, but certainly deserves a joint consideration.
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Marc Snir Sent: Thursday, October 20, 2011 10:40 PM To: [email protected] Subject: [Mpi3-hybridpm] endpoint proposal
Slides and text for the endpoint proposal
-------------------------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen, Deutschland Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr./VAT Registration No.: DE129385895 Citibank Frankfurt a.M. (BLZ 502 109 00) 600119052
_______________________________________________ Mpi3-hybridpm mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-hybridpm
-- Pavan Balaji http://www.mcs.anl.gov/~balaji -------------------------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen, Deutschland Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr./VAT Registration No.: DE129385895 Citibank Frankfurt a.M. (BLZ 502 109 00) 600119052
participants (1)
Supalov, Alexander
