Hi Joseph, all, I played around to get this running with Fortran a while ago. Here is the code, I wrote based on my initial interface: https://github.com/jprotze/fortran-detach/blob/main/detach-mpi/test-mpi-deta... I ran into the issue, that one of the few implementations supporting detached tasks (Cray) did not allow me to take the address of the OpenMP function - which was not an Fortran-specific issue. GCC/11 works both ways. Interestingly, ifort still doesn't seem to support detached tasks, although the feature originally was an Intel proposal. Best Joachim Am 04.08.21 um 20:02 schrieb Joseph Schuchart via mpiwg-hybridpm:
Thanks Jeff! I am less worried about the out-of-band update of the status objects but the whole thing with callbacks and function pointers. The only place in the MPI standard using callbacks right now is the tools chapter and that is explicitly C-only. Looking at https://scicomp.stackexchange.com/a/286 it seems to be possible to pass around function pointers in Fortran but the comments suggest that its not compatible with C?
Thanks Joseph
On 8/4/21 1:00 PM, Jeff Hammond wrote:
Regarding Fortran…
In theory, you need ASYNCHRONOUS/VOLATILE attributes on visible state that’s updated out of band.
In practice, MPI implementations have done this with nonblocking send-recv for 25 years and it hasn’t been an issue.
Sent from my iPhone
On Aug 4, 2021, at 7:36 PM, Joseph Schuchart via mpiwg-hybridpm <[email protected]> wrote:
Dear all,
I have written and attached a first draft of the continuations section that I would like to discuss in one of the upcoming meetings. Right now it is embedded at the end Section 3 (Point-to-Point following test and wait etc) where I felt it would fit well, I'm open to other suggestions though.
There are still some open TODOs that I'd like to discuss. In particular, I'm grappling with the handling of statuses. As suggested during previous discussions, I removed the flag argument to MPI_Continue such that the MPI implementation is allowed to invoke the continuations directly (can be controlled through an info key though). That means that after the call to MPI_Continue there is no good reason to inspect the statuses anymore. However, we may still want the user to provide the status object(s) in order to avoid exposing implementation-internal memory in the callback. But then I am worried that this is a source of error, with users providing pointers to stack memory that goes out of scope before the continuation is invoked.
Also, I am unsure whether and how this whole mechanism works with Fortran. The python generator happily generates the interface but I have no idea whether that is correct...
Looking forward to discussing this on the call!
Cheers Joseph <mpi40-report-continuations.pdf> _______________________________________________ mpiwg-hybridpm mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-hybridpm
-- Dipl.-Inf. Joachim Protze IT Center Group: High Performance Computing Division: Computational Science and Engineering RWTH Aachen University Seffenter Weg 23 D 52074 Aachen (Germany) Tel: +49 241 80- 24765 Fax: +49 241 80-624765 [email protected] www.itc.rwth-aachen.de
participants (1)
Joachim Protze
