Re: [mpiwg-hybridpm] Process -> MPI process change
Hi, I may have a simple way of fixing my changes which, if it works, could be used to fix Dan’s changes. Let me see what I can do. - Steve -----Original Message----- From: mpiwg-hybridpm <[email protected]> on behalf of Jeff Hammond <[email protected]> Reply-To: "[email protected]" <[email protected]> Date: Wednesday, June 8, 2016 at 5:00 PM To: "[email protected]" <[email protected]> Cc: "[email protected]" <[email protected]> Subject: Re: [mpiwg-hybridpm] Process -> MPI process change
mea culpa
i'll provide free coffee to whoever fixes my bug. you can collect your free coffee at any Intel campus ;-)
jeff
On Wed, Jun 8, 2016 at 2:47 PM, Steven Oyanagi <[email protected]> wrote:
First off, sorry, but I probably won’t be able to get the changes done today. At this point I suspect you don’t need them for this meeting. If you do, let me know and I will try to get them done quick.
I do note we have not be consistent about putting things in as \MPI/. I note that Jeff Hammond’s change on Mar 1 (7c911456d - change process to MPI process) did not use \MPI/. Pavan’s mod is right, it did use \MPI/. Dan’s mod (12aa5e1c - Clarification of word 'process', pages 101-200 from Feb 5th does *not* use \MPI/, it inserts “MPI “. It may be I looked at Dan’s mod and thought it was Pavan’s. - Steve
-----Original Message----- From: Pavan Balaji <[email protected]> Date: Wednesday, June 8, 2016 at 2:28 PM To: "[email protected]" <[email protected]> Cc: Pavan Balaji <[email protected]>, Steve Oyanagi <[email protected]> Subject: Re: [mpiwg-hybridpm] Process -> MPI process change
Steve,
You should use \MPI/ in latex.
-- Pavan
On Jun 8, 2016, at 11:33 AM, Steven Oyanagi <[email protected]> wrote:
Sorry, I was unclear in my last message. Changes were made per the review of changes for pages 201-300 in previous working group meetings. My inquiry was about the changes to the TEX source of the MPI standard. Did I have to do anything unusual in the case where “MPI “ was inserted? I just inserted the string “MPI “ in those cases. MPI isn’t some special tag that has be denoted in an different way, is it? - Steve
-----Original Message----- From: Steve Oyanagi <[email protected]> Date: Wednesday, June 8, 2016 at 11:27 AM To: "[email protected]" <[email protected]> Subject: Re: [mpiwg-hybridpm] Process -> MPI process change
I think I have the changes for 201-300 done and correctly committed to the branch. Please check that I got the git stuff correct, and take a glance at my commit to make sure I didn’t forget to do something. I assume in most cases I just had to insert “MPI “ before process. Was I suppose to do anything else?
Please let me know if further changes are needed. - Steve
-----Original Message----- From: Steve Oyanagi <[email protected]> Date: Tuesday, June 7, 2016 at 6:12 PM To: "[email protected]" <[email protected]> Subject: Re: [mpiwg-hybridpm] Process -> MPI process change
Hello,
FYI - I have the changes done, just need to proof-read a bit and then will commit, probably tonight or tomorrow morning. Hope that’s soon enough for you folks. - Steve
-----Original Message----- From: mpiwg-hybridpm <[email protected]> on behalf of Pavan Balaji <[email protected]> Reply-To: "[email protected]" <[email protected]> Date: Tuesday, June 7, 2016 at 1:46 PM To: "[email protected]" <[email protected]> Subject: Re: [mpiwg-hybridpm] Process -> MPI process change
Steve,
Thanks. If you are unable to push the changes in due to access regions, you can send your patch to me. I'll apply it.
I'll try to figure out who can make the change to the reply-to field.
-- Pavan
On Jun 7, 2016, at 1:38 PM, Steven Oyanagi <[email protected]> wrote:
Hi Pavan,
Sorry, I never got around to actually making the changes. I had problems finding the repositories until I discovered that I had never gotten access to them. Since then I ran out of time to work on the changes.
Now that they are a priority, I will try to get this done quickly. Most of the changes are straight-forward.
Also - E-mail from he mailing list comes with the wrong “Reply-To” field. I got burned by this once before (Jim Dinan graciously pointed me to the right address) but I didn’t realize the issue was in the message. I think the “Reply-to” field below should be "[email protected]”. Note that the address in the Reply-to field is missing the “lists.” part. - Steve
-----Original Message----- From: mpiwg-hybridpm <[email protected]> on behalf of Pavan Balaji <[email protected]> Reply-To: "[email protected]" <[email protected]> Date: Tuesday, June 7, 2016 at 1:19 PM To: "[email protected]" <[email protected]> Subject: [mpiwg-hybridpm] Process -> MPI process change
Hi Steve,
We had gone over your changes from "process" to "MPI process" for pages 201-300 in one of the previous telecons, but we don't see your changes in git. Did you commit your changes in? If not, can you please commit them as soon as possible into the `origin/hybrid-process-clarification` branch on [email protected]:mpiwg-hybrid/mpi-standard.git?
-- Pavan
_______________________________________________ mpiwg-hybridpm mailing list [email protected]
http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-hybridpm <http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-hybridpm>
_______________________________________________ mpiwg-hybridpm mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpiwg-hybridpm
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Steven Oyanagi
