Re: [Mpi3-hybridpm] Reminder for the hybrid telecon tomorrow
Would we actually specify what "not being initialized" anymore means, except that users are no longer allowed to call MPI routines before they call MPI_Init again? If so, the impact on the implementation should be minimal, since it could just keep MPI "alive" under the hood. Martin On Apr 22, 2013, at 12:08 PM, Jim Dinan <[email protected]> wrote:
I think the new semantics for MPI_Init() would be backward compatible, but we could also add a new routine: MPI_Init_awesome(). :)
On 4/22/13 11:42 AM, Jeff Squyres (jsquyres) wrote:
Sayantan and I talked about this on the phone today. It seems like re-initialization might be a good idea, but a good first step might be asking all the hardware/software vendors if there's a technical reason they don't allow re-initialzation today (other than "because it's not required by MPI"). I.e., I think that some API's/networks (like PSM) don't allow re-initialization -- is there a technical reason for that, or is it just an overcome-able software limitation?
I'm not a big fan of re-defining the default behavior of MPI_INIT, however -- I think there might be a big impact on legacy applications.
On Apr 19, 2013, at 3:06 PM, Jim Dinan <[email protected]> wrote:
Another issue that ought to consider is that MPI currently can only be initialized/finalized once. This requirement breaks the "MPI is a library" semantic and leads to some of the nastiness Jeff S. mentioned below. I think we should re-evaluate if this restriction is really required, or if it's just convenient for implementers.
Another suggestion on this front -- Why not modify the semantics of MPI_Init to match what we want?
MPI_Init:
- Always THREAD_MULTIPLE - Always a thread safe call - Ref-counted - Can be used to initialize/finalize MPI multiple times - Cannot be combined with MPI_Init_thread
If apps really care about getting rid of threading overhead, then they should use MPI_Init_thread() and use the thread level argument to give a performance hint.
~Jim.
On 4/19/13 1:11 PM, Jeff Squyres (jsquyres) wrote:
Points to think about for the Monday teleconf...
With regards to ref-counted MPI_INIT / MPI_FINALIZE (https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/302):
PROBLEMS IT SOLVES: - multiple, separate libraries in a single process needing access to MPI ==> works best when all entities call MPI_INIT* at the beginning of time, work for a "long" period of time, and then call MPI_FINALIZE at the end of time (i.e., there's no race condition -- see below)
PROBLEMS IT DOES NOT SOLVE: - Implementation not providing MPI_THREAD_MULTIPLE support (e.g., if the separate libraries are in different threads and someone already initialized MPI with THREAD_SINGLE, other threads can't know if it's safe to call MPI_INIT* or not) - The "finalize" problem (i.e., can't guarantee to know if MPI has been finalized or not -- there's a race between calling MPI_FINALIZED, seeing that MPI is not finalized, and then calling MPI_INIT)
PROBLEMS IT CREATES: - Will need to change the definition of "main thread" - Possibly also need to change the definitions of MPI_THREAD_SERIALIZED and MPI_THREAD_FUNNELED
OPEN QUESTIONS: - Do we still need to keep the restriction that the thread that initializes MPI is the same thread that finalizes MPI? - Should we allow re-initialization? This effectively solves some (but not all) of the problems that have been discussed, but probably opens a new can of worms...
On Apr 12, 2013, at 8:27 AM, Pavan Balaji <[email protected]> wrote:
All,
Jim and I will be late for the April 22nd meeting. So we decided to move the endpoints discussion to the telecon after this one.
I chatted with Jeff Squyres yesterday. He'll be driving the April 22nd telecon to discuss more details on the ref-counted init/finalize issue. He'll be sending out some notes before the call for discussion.
-- Pavan
On 04/08/2013 11:47 AM US Central Time, Pavan Balaji wrote:
The next call will be on April 22nd, 11am central. Same telecon number.
-- Pavan
On 04/08/2013 11:42 AM US Central Time, Jim Dinan wrote:
Meeting notes are on the wiki:
https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/MPI3Hybrid/notes-2013-04-0...
~Jim.
On 4/7/13 12:45 PM, Pavan Balaji wrote:
All,
This is a reminder that we'll have our hybrid telecon tomorrow at 11am. Here's the telecon information:
International dial-in number: 1-719-234-7800 Domestic dial-in number: 1-888-850-4523 Participant Passcode: 314159
The main item we'll be discussing is Jeff Squyres' ref-count proposal.
-- Pavan
_______________________________________________ Mpi3-hybridpm mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-hybridpm
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
________________________________________________________________________ Martin Schulz, [email protected], http://people.llnl.gov/schulzm CASC @ Lawrence Livermore National Laboratory, Livermore, USA
participants (1)
Schulz, Martin
