Re: [Mpi3-ft] Point2Point issue scenario with synchronous notification based on calling communicator only.
The failure happened in MPI_COMM_WORLD. I assume that for this case, the fault tolerance strategy of library A is based on collective repair. Do you propose to forbid using collective repairs if the user uses such communication scheme? How do you propose to deal with the following example: MPI_COMM_WORLD is the communicator used in library A MPI_COMM_2 is the communicator used in library B rank 0: belongs to MPI_COMM_WORLD *and MPI_COMM_2* -> in library A: do some computation and communications that succeed -> in library A: computes a reversible checksum -> in library A: continue computation, calling other libraries often -> then, at some point in time: -> in library A: MPI_Send(MPI_COMM_WORLD, dst=1); -> crashes -> would have entered library B and here do no communications at this step rank 1: belongs to MPI_COMM_WORLD and MPI_COMM_2 -> in library A: do some computation and communications that succeed -> in library A: computes a reversible checksum -> in library A: continue computation, calling other libraries often -> then, at some point in time, -> in library A: MPI_Recv(MPI_COMM_WORLD, src=0) -> detects the failure -> calls the error manager: collective repair -> would have entered library B and called: MPI_Send(MPI_COMM_2, dst=2); rank 2: belongs to MPI_COMM_WORLD and MPI_COMM_2 -> in library A: do some computation and communications that succeed -> in library A: computes a reversible checksum -> in library A: continue computation, calling other libraries often -> then, at some point in time, -> in library A: does not have to communicate at this step -> in library B: MPI_Recv(MPI_COMM_2, src=1); -> will never succeed To inverse the reversible checksum, the rank 2 needs to enter the collective repair, in order to give to the new rank 0 the data that rank 0 lost with the crash. It is not because the library uses a collective approach for tolerating failures that it needs to do synchronizations all the time when it calls other libraries: if library A highly depends on lower-level libraries, it does not want to synchronize each time it is going to make a call, but it is OK to synchronize for time to time to compute the reversible checksum. Thomas 2009/2/10 Erez Haba <[email protected]>
Don't' do collective repair in rank 1. Do a non-collective repair (rank 1 does not require the participation of rank 2 to recover rank 0)
*From:* [email protected] [mailto: [email protected]] *On Behalf Of *Thomas Herault *Sent:* Monday, February 09, 2009 4:47 PM *To:* MPI 3.0 Fault Tolerance and Dynamic Process Control working Group *Subject:* [Mpi3-ft] Point2Point issue scenario with synchronous notification based on calling communicator only.
Hi list,
with the help of others, here is an adaptation of the "counter-example" based on p2p communications only.
rank 0: belongs to MPI_COMM_WORLD only
-> crashes
-> would have entere library B and called: MPI_Send(MPI_COMM_2, dst=2);
-> does nothing in library A except entering library B.
I understand from the discussion we had that a solution would be to validate COMM_WORLD for process 2 before entering library 2. I agree with that, but would like you to consider that it virtually means that we ask users to call a $n^2$ communications operation before any call of any function of any library (and possibly at the return of calls) if they want to use collective repairs. I would advocate studying a less performance-killer approach, where errors of any communicator would be notified in any MPI call.
Bests,
Thomas
_______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
participants (1)
Thomas Herault
