Re: [Mpi3-ft] Asynchronous error handling
On the telecon today we agreed to have our next telecon on 6/6 focus on how we may handle asynchronous error notification within MPI. The working assumption is that we will still have return error codes, but also make use of asynchronous notification. We need to - Clearly define the boundary between these two different error notification mechanisms, i.e., when we use one and when the other - Define the precise mechanism for asynchronous error notification This e-mail is intended to jump start discussion in preparation for the next telecon.
I'll throw something out here. I wasn't around for the initial discussions, so some of this may fly in the face of something that people have already decided is obviously wrong. Either way, its a start. You may commence with the tomato throwing. The idea for this proposal is a publish-subscribe model where the spec defines the default publish-subscribe relations but allows MPI implementations to define new events and default and allows applications to cancel/add new event subscriptions. I like this model mostly because it is the one being used by the CIFTS project, which I suspect will have an important role to play in MPI application fault tolerance. Since we won't be able to list all the possible errors that may occur, we'll need to define the possible error types and describe describe the error notification properties of these broad types, rather than individual events. Implementations may then put each real error into any type that is deemed appropriate. Every error will have a defined detection set, which is the set of processes that by default subscribe to being notified of this event. For example, if a given process fails, any process that tries to receive a message from this process is definitely within its detection radius. However, if the failed process is a receiver in a broadcast, we may or may not choose to include the other broadcast receivers in the detection radius (probably not). Each process is subscribed to all error events that happen in the process, as long as the errors don't cause the process itself to fail. For each failure event type we will define the latest point in time when each process within the event's detection set will be notified. For example, if process p fails, all other processes must be notified no later than their next receive call that must receive from p (i.e. receives with MPI_ANY_SOURCE don't qualify). For errors that cause process state to be corrupted, we may want to inform other processes no later than the first point in time when their state becomes dependent on the corruption. The MPI implementation may deliver the event at this latest point using the synchronous error API or at any earlier point in time using the asynchronous API. The synchronous API will be a direct extension of the current error reporting API. The asynchronous API will take the form of an events queue that may be explicitly polled by the application to see if there are any pending events. Applications will also be able to register a callback function that will automatically be called by MPI whenever a new event arrives. Furthermore, processes may subscribe to events emanating from other processes as they see fit. For example, the application may designate one or more processes as error monitors and these processes would register themselves to listen to all other processes and take appropriate corrective measures if something goes wrong. Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected]
participants (1)
Greg Bronevetsky
