Re: [Mpi3-ft] system-level C/R requirements
Thanks. I think the word "how" below is decisive. The definition of MPI_Init and MPI_Finalize do not say "how" processes are created, and still, they work. Likewise, as soon as we can define the expected outcome of the proposed calls, we can offload the "how" to the system - in this case, the CR system. Now we come to the expected outcome. Imagine we guarantee that there's no MPI communication between the PREPARE and RESTORE calls, and no messages stuck in the wire or in the buffers. What can be stored in the system memory covered by CR will be stored there. The rest will be restored by the RESTORE call once it gets control over this memory image back. This may include reinitialization of the networking hardware, reestablishment of connections, reopening of the files, etc. What other guarantees do CR people want? -----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Greg Bronevetsky Sent: Friday, October 24, 2008 11:38 PM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group; MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] system-level C/R requirements The imprecision comes from the MPI library's interactions with the C/R tool. It seems to me that each tool/MPI library combo will have to define their own semantics for the two calls. The only standard here would be that these functions would in fact need to be called. But at this point its not really an API but a mild constraint on how the real API would be used. As such, it doesn't carry much information about how checkpointing is to be done. What the system-level C/R people need is a set of guarantees about where MPI will put its state between the two calls. I don't see a way to give them such guarantees in a standardized way. This is where we get stuck: we either provide a couple of calls that has little informational content but rather server as placeholders for a real or go fully detailed on a platform-by-platform basic. Neither approach is likely to pass by the wider forum, which is why I don't know how to satisfy this need within the MPI 3.0 effort. It looks to me like we're standardizing something that is already non-standard. Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected] At 02:27 PM 10/24/2008, Supalov, Alexander wrote:
Thanks. Can (or should) one define semantics better than those of the MPI_INIT and MPI_FINALIZE? MPI job starts after MPI_Init. The job ends after MPI_Finalize. What happens before and after is almost undefined. This is about all the standard specifies, and it's rather clear why: it cannot prescribe the way in which processes are started, because it's very system specific. CR is possibly even more system specific.
Let's get back to the proposal:
MPI_PREPARE_FOR_CHECKPOINT(MPI_COMM) ~ MPI_FINALIZE MPI_RESTORE_AFTER_CHECKPOINT(MPI_COMM) ~ MPI_INIT
Use MPI_COMM_WORLD for global CR. Use MPI_COMM_SELF for local CR.
Call the first function immediately before the checkpoint, do the checkpoint the way you like, and call the second immediately after to re-enter the MPI session where you left it.
What else can be added to make this more clear and more precise than MPI_INIT and MPI_FINALIZE definitions?
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Greg Bronevetsky Sent: Friday, October 24, 2008 11:14 PM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group; MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] system-level C/R requirements
I think that the problem for the forum will be the unclear semantics of the new calls. MPI_Init is not a good example because it has clear semantics for all users of MPI but not system-level services. The difference with the quiscence calls is that we're trying to provide a way to by-pass to regular MPI semantics and plug into the middle of MPI without precisely defining how the by-pass works. Precise semantics didn't matter for MPI_Init exactly because there has never been a way to look into the MPI implementation until now. The solution to this is to provide very loose semantics to the new calls but this just means that there will actually be no standard way to use the new calls, which is why I'm afraid the forum will not like it.
I can think of only two things that we can compare these calls to. The first is the proposed performance hint API. However, this API is just about hints and may not be a good enough analogy for the rest of the forum. The other analogy is the performance profiling APIs that some MPI implementation support. These APIs allow tools to determine some statistics about internal MPI state. If that is the analogy that is drawn, then it is bad for this proposal because I don't think that the performance profiling API ever got much support because of the issues that we're discussing here.
At 02:03 PM 10/24/2008, Supalov, Alexander wrote:
Thanks. I can't speak for the whole Forum, but my impression is that if the choice will be between solving the problem of MPI and CR on one hand, and not solving it on the other hand, a reasonable proposal will go a long way toward convincing the majority, or at least moving the discussion to a still better proposal.
As for the number of calls, this is question of ROI. We're going to add 200 or so fancy calls by the latest guess, while here we have just 2 that offer basic functionality of undeniable value. This should be acceptable.
Finally, I don't know a more implementation specific call than MPI_Init. The proposed calls live close nearby.
_______________________________________________ mpi3-ft mailing list [email protected] http:// lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
_______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
Supalov, Alexander
