Re: [Mpi3-ft] Latest version of chapter
On Oct 21, 2011, at 3:37 PM, Sur, Sayantan wrote:
Hi Darius,
-----Original Message----- From: [email protected] [mailto:mpi3-ft- [email protected]] On Behalf Of Darius Buntinas Sent: Friday, October 21, 2011 12:35 PM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] Latest version of chapter
With (regular) error handlers, they'll be called from within the function that raises the error. With failure notification, because they're being called as a result of an external event (process failure), you could be called from within any function, even one not related to the comm/file/win that you registered the process failure notification handler on.
Does that make sense?
OK. I thought that this would violate the spirit (if not the letter) of the rationale in 17.5 just before this.
"These semantics allow a process to continue running without being interrupted by the failure of processes with which they may never or rarely communicate."
The process will only set the handler if it wants to be notified of failures. If it doesn't set the handler, then it won't be interrupted (of course the MPI library might be interrupted and do some processing for every failure notification, but that's transparent to the user).
Also, aren't normal error handlers only called from within related calls? If FT handlers can be called from anywhere, then it (at least) merits a clear description in that it deviates from normal error handlers (in addition to Alexander's concerns).
Sure, we'll probably also need to specify what kind of operations are allowed to be performed from inside the handler (e.g., can you call MPI_Send? can you free the comm/win/file in question?) -d
Thanks.
-d
On Oct 21, 2011, at 1:51 PM, Sur, Sayantan wrote:
17.5.1:11-12 - "The error handler function will be called by the MPI implementation from within the context of some MPI function that was called by the user."
Maybe we should that error handlers are called from MPI functions that are associated with that comm/file/win?
-----Original Message----- From: [email protected] [mailto:mpi3-ft- [email protected]] On Behalf Of Josh Hursey Sent: Friday, October 21, 2011 10:28 AM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] Latest version of chapter
I just wanted to note that we want to distribute a copy of this chapter to the MPI Forum before the meeting. As such we are planning on sending out a copy at COB today (so Friday ~5:00 pm EDT) so that people have an opportunity to look at the document before the Monday plenary. So please send any edits or comments before COB today, so we can work them into the draft.
We will post the draft to the ticket, so that people know where to look for the current draft.
Thanks, Josh
On Thu, Oct 20, 2011 at 7:06 PM, Darius Buntinas <[email protected]> wrote:
Here's the latest version of the FT chapter is on the wiki (it's in
a new location on the main FT page under "ticket #276". Please have a look and comment.
Here's a direct link to the PDF: https://svn.mpi-forum.org/trac/mpi-forum-web/raw-
attachment/wiki/FaultToleranceWikiPage/ft.pdf
Here's a summary of the changes Josh and I made:
* Minor wording touchups * Added new semantic for MPI_ANY_SOURCE with the
MPI_ERR_ANY_SOURCE_DISABLED error code
* Coverted wording for all comm, win, fh creation operations to not require collectively active communicators (eliminate requirement for synchronization) * Added missing reader_lock to ANY_SOURCE example * Added case for MPI_WIN_TEST
and
One-sided section clarified that window creation need not be blocking clarified that RMA ops might not complete correctly even if synchronization ops complete without error due to process failures Process failure notification Added section describing new functions to add callbacks to comms, wins and files that are called when proc failure is detected Other wordsmithing/cleanup changes
-d _______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
-- Joshua Hursey Postdoctoral Research Associate Oak Ridge National Laboratory http://users.nccs.gov/~jjhursey
participants (1)
Darius Buntinas
