Re: [Mpi3-ft] A need to detect any failure
What we're focusing on right now is the most basic notification mechanism that needs to be supported by MPI. This is the notification mechanism that will be used with legacy applications that use error codes to be informed of errors and need sensible default behavior from MPI. Although your use-case makes sense, the extra cost that it would incur means that applications that need this capability are best off using a more complex/customizable API, such as the publish-subscribe API we've been tossing around. Also, the idea of passing error notifications on top of existing messages is good motivation for the piggybacking API. In any case, I think that this is a use-case for the extended notification API, not the default notification mechanism. Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected] At 11:03 AM 8/1/2008, you wrote:
Hi all, I like Erez's idea to associate errors with call sites. However, I still believe there is a case where processes do not communicate with each other directly, but will need to know when any process in the system dies. Here is an example.
Let's say an application splits MPI_COMM_WORLD into a 2d cartesian grid. Then each process creates a "row" communicator and a "column" communicator. From here on out, each process only communicates through its row and column communicators. (I think this is what a number of our codes really do, so this is a very realistic example). In the case of a failure, assume this application requires a global rollback, and assume that each process writes a checkpoint file at the end of each iteration, which looks like the following:
for (iteration=0; iteration<numTimesteps; iteration++) { row_xchange(); column_xchange(); compute(); checkpoint(iteration); }
Now consider processes (i, j) and (i+1, j+1) in this 2d cartesion grid. Because these two processes are in different rows and columns, they don't share a row or column communicator, and so they never communicate with each other directly. Now, assume process (i+1, j+1) fails. Process (i, j) needs to rollback, but how will it be notified?
One solution would be to force the application to call MPI_Barrier(MPI_COMM_WORLD) inside of its iteration loop. While this would work, it seems costly, and it defeats all the effort the application team went to in order to make the code scalable by using just row and column communicators.
Another solution may be to rely on daisy chaing. That is, in the next iteration after process (i+1, j+1) dies, processes (i+1, j) and (i, j+1) may find out since they each share a communicator with the failed process. Then in the following iteration, processes (i+1, j) and (i, j+1) could propogate this failure message to process (i, j) since they each share a communicator. This would also work, but a special error code would be needed since the communication with (i+1, j) and (i, j+1) may have succeeded just fine.
In the current standard, MPI handles this type of failure by invoking the error handler on MPI_COMM_WORLD. This could be yet another solution. -Adam _______________________________________________ mpi3-ft mailing list [email protected] http:// lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
participants (1)
Greg Bronevetsky
