Re: [Mpi3-ft] The state of MPI is undefined
Hi Josh,
How about: ------------------ MPI does not provide the user with transparent process recovery upon process failure. Once a process fails, MPI does not guarantee that the job can continue or, if the job can continue, that the process can be recovered. If a process failure occurs, and the MPI implementation is able to correctly continue operating after process failure then the MPI implementation will return an appropriate error class (e.g., MPI_ERR_RANK_FAIL_STOP) and provide the additional semantics defined in Chapter 17. The MPI implementation documentation will provide information on the possible effect of each supported class of errors.
Advice to users: It is possible that the state of MPI becomes corrupted in an undetectable manner. This undetectable error might force the MPI implementation to return an error code (or even success) unintentionally. For this pathological case there exist no mechanisms to determine the correct running state. A high-quality implementation will strive to return the correct return code from all MPI operations. ------------------
I vote for this wording. Howard -- Howard Pritchard Software Engineering Cray, Inc.
participants (1)
Howard Pritchard
