Re: [Mpi3-ft] system-level C/R requirements
Probably we should not try to define this, and encourage checkpoint/restart people work with particular MPI implementations to make sure things work? After all, it's not about an abstract MPI and abstract CR system - there will probably always be actual pairs (or other relationships) of them that can work together. Compare this to the situation with threads. MPI acknowledges their existence and provide a couple of calls to request a particular level of support, that's all. This was good enough for starters, and may change in the future. The relation between MPI and CR may go this way, too: acknowledging first, integrating next. -----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Greg Bronevetsky Sent: Friday, October 24, 2008 10:38 PM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group; MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] system-level C/R requirements My problem is that while this has clean semantics for an application-level checkpointer, the same is not true for a system-level checkpointer. In the latter case the checkpointer can exactly capture an undefined subset of MPI state (ex: main memory state but not network card state). As such, MPI_PREPARE_FOR_CHECKPOINT would essentially tell MPI to pull all of its state into the subset that can be checkpointed by the system-level checkpointer. However, the subset depends closely on the type of checkpointing being performed, which itself is very system-specific. As such, I don't know how to provide semantics for this call without using low-level language. Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected] At 01:32 PM 10/24/2008, Supalov, Alexander wrote:
Hi everybody,
I'm afraid we're overcomplicating things a little here. What we need are basically two collective calls:
MPI_PREPARE_FOR_CHECKPOINT MPI_RESTART_AFTER_CHECKPOINT
The former is (almost) like MPI_Finalize, the latter is (almost) like MPI_Init. What they mean is up to the implementation, with one condition: it must be possible to do actual checkpoint/restart in between.
I cannot exclude that the exact meaning of the calls and the notice will be influenced by implementation details like memory registration, the checkpoint/restart system used, the network involved, etc.
These collective calls may be complemented by individual, non-collective calls if needed. They will be suitable for individual checkpoint/restart, and the user will have to make sure no bad things happen, like messages trying to reach a process, the memory of which is currently being dumped.
Best regards.
Alexander
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Greg Bronevetsky Sent: Friday, October 24, 2008 10:21 PM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group; MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] system-level C/R requirements
Agreed -- specifiying an explicit list of platforms or OS or even resource specifics is not the way to go in a standard.
My suggestion would be to explore if we can define abstract, higher-level resources to define a "state", and specify high-level actions. For instance, pinning/unpinning memory is very specific to RDMA, but maybe a "disconnect virtual connection" operation may abstract it. But this puts us into the realm of virtualizing MPI internal components/concepts ..
Maybe there is a more elegant way ... The thing that worries me is that an MPI implementation may have a fair amount of state sitting on the network card. This state is unreachable by a user- or kernel-level checkpointer but may be reachable by a VMM-level checkpointer. How do we differentiate the level at which we're working? System-level checkpointers working at different levels need MPI state to be flushed to different levels of abstraction and it seems that we'll need to be very low-level in order to define what it means to operate at a given level of abstraction.
_______________________________________________ mpi3-ft mailing list [email protected] http:// lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
_______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
Supalov, Alexander
