Thanks. Unfortunately, I have to miss today's meeting for another one. Good luck. -----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Josh Hursey Sent: Wednesday, February 17, 2010 4:58 PM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] Con Call On Feb 17, 2010, at 9:00 AM, Supalov, Alexander wrote:
Thanks. I guess being as vague as the non-blocking collective proposal wrt the max number of pending spawns is a sound approach.
What about the connection to the "main" FT API (that hasn't been updated for quite a while, as it seems)? E.g., what happens if a non- blocking spawn fails? When is the right time to start thinking about this sort of scenarios?
I have not tried to explicitly relate the two proposals yet. Since I don't think that the dynamics, onesided, or file management operations are currently handled by the current FT API proposal, I didn't want to add more interfaces to the list just yet as to not slow down the progress on that proposal. Keeping the two proposals separate at the moment is probably the best. But certainly they will be dependent if they both get out of the working group. For the moment I thought it best to consider them separately.
Also, in connection to this, it may be that a priori elimination of the MPI_Cancel in application to the spawning operations is not a good thing. If the non-blocking spawn will fail collectively, we don't need cancel. If they won't, we do.
We eliminated MPI_Cancel for the spawn operations since they are collective, and, taking president from nonblocking collectives, do not have well defined cancelation semantics. That being said, we do allow for the cancelation of accept/connect which are also collective. This is something that I hope to talk a bit about on the teleconf today. Without the FT API proposal, the failure behavior of the nonblocking spawn operations should match those of the blocking versions. We should probably make a note of that in the proposal. -- Josh
-----Original Message----- From: [email protected] [mailto:[email protected] ] On Behalf Of Josh Hursey Sent: Wednesday, February 17, 2010 2:03 PM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] Con Call
On Feb 17, 2010, at 7:14 AM, Supalov, Alexander wrote:
Dear Josh,
Thank you. A couple of questions if you permit:
1. Did anyone from the Collective WG look into this proposal?
Not yet. I wanted the FT WG to take a few passes before I brought in the Collective WG. I have been looking over the Nonblocking Collectives chapter, and taking president/ideas from there on how to form some of the Nonblocking Dynamics.
2. How many simultaneous outstanding spawns are allowed on a communicator?
I don't think this is specified in the standard for other nonblocking operations. For example with isend the MPI implementation might fall over (hopefully just by returning an error, but that will likely lead to abort()) at some point if there are too many isends posted due to memory or other internal constraints. But the limitation is purely MPI implementation and system dependent, so I don't think the standard should specify this.
So the short answer is, as many as the MPI implementation allows, but the MPI standard does not specify any such limit. Do you think that we need an advice to users on this point?
3. You use "I" right after the "MPI_", thus creating "MPI_ICOMM_*" names. Maybe it's better to say "MPI_COMM_I*" where appropriate?
Here I just followed the president set by the standard of "MPI_I*". However "MPI_COMM_I*" seems to sound better. What do others think about this?
4. What, apart from symmetry, motivates introduction of the MPI_ICOMM_JOIN?
Symmetry, and since it is a blocking operation dependent upon a remote process there is potential for comm./comp. overlap.
I know there has been some discussion about deprecating MPI_COMM_JOIN, but I wanted to move that discussion to another ticket. I think that the nonblocking dynamics and deprecating comm_join should be two separate discussions, even though the outcome of one will likely affect the other.
-- Josh
Best regards.
Alexander
-----Original Message----- From: [email protected] [mailto:[email protected] ] On Behalf Of Joshua Hursey Sent: Wednesday, February 17, 2010 1:06 PM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] Con Call
I have updated the wiki page for "Nonblocking Process Creation and Management Operations" per our meeting today. https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/Async-proc-mgmt
-- Josh
On Feb 16, 2010, at 9:16 PM, Graham, Richard L. wrote:
Reminder that we will have a con-call tomorrow, Wed 2/17/2010, at 12 noon EST.
Rich
_______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
_______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
_______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
Supalov, Alexander
