Hi all, The Fault Tolerance Working Group will be doing 2 readings at the upcoming meeting. 1. Define error/failure behavior in MPI_INIT/FINALIZE * Issue - https://github.com/mpi-forum/mpi-issues/issues/102 * Pull Request - https://github.com/mpi-forum/mpi-standard/pull/50 This issue pulls out the definitions around error behavior for `MPI_INIT` and `MPI_FINALIZE`. This comes from #20, but is not directly related to the fault tolerance parts of that proposal. 2. Clarify what MPI_SUCCESS guarantees, and what is left undefined when MPI_ERR_XXX happens * Issue - https://github.com/mpi-forum/mpi-issues/issues/119 * Pull Request - https://github.com/mpi-forum/mpi-standard/pull/95 Add text to clarify what is implied about the status of MPI and user visible buffers when MPI functions return `MPI_SUCCESS` or other error codes. Thanks, Wesley
participants (1)
Bland, Wesley
