[Mpi3-ft] RTS proposal update in MPI Forum SVN
I updated the RTS proposal in SVN (trunk/working-groups/mpi-3/ft/trunk). I pulled out the errhandler_compare and mpi_comm_kill functions into separate tickets. I also did some of the smallish changes suggested by the MPI Forum in July. Full change log at bottom. I think the PDF is ready to be updated with the new state management functionality. There are some other edits that we need to do, but until the new state management functionality is in place it does not make much sense to do. Let's wait for the teleconf on Wed. before adding to the RTS proposal. Then we can make a game plan for updates. That is unless someone is really eager to go for it before the teleconf (post to the list if so). -- Josh Change Log: ------------------ * Separate Ticket: MPI_ERRHANDLER_COMPARE * https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/291 * Separate Ticket: MPI_COMM_KILL * https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/292 * 8.2: In table with MPI_ERR_RANK_FAIL_STOP, change 'is failed' to 'has failed' * 8.3: "in the associated communicator' does not account for error handlers on windows or file handles. So change to something like 'in the associated communication handle' * 8.3: use 'associated' instead of 'specified' * 8.7: Rank 0 and MPI_Finalize. Moved advice to users to FT chapter. Left a forward reference in this chapter. Addressed some of the concerns with this wording. * 17.1: Clarify 'Such applications' in the second paragraph. Should be 'Process fault tolerant applications' * 17.2: 'alive process' remove 'normal' or define as 'not failed' * 17.3: 'Rationale' replace 'to deadlock situations' with 'to deadlocks' in last sentence. * 17.3: 'Advice to implementors' replace 'where able' with 'if able' or 'if possible' in last sentence. * 17.4.1: Typo on page 539 line 43 - "indicates the state of process in the associated..." -> "indicates the state of the process the associated..." * 17.7: Paragraph 1, sentence 1 conflicts with the last sentence of paragraph 2. This should be fixed. * 17.7: It was mentioned that it would be useful to explicitly mention that a point-to-point operations should not hang in the presence of errors, that they will eventually return with either success or some error. -- Joshua Hursey Postdoctoral Research Associate Oak Ridge National Laboratory http://users.nccs.gov/~jjhursey
participants (1)
Josh Hursey
