Re: [Mpi3-ft] system-level C/R requirements
Le 27 oct. 08 � 17:16, Joseph Ruscio a �crit :
On Oct 27, 2008, at 7:18 AM, Thomas Herault wrote:
So, my question is: what are the benefits of solution b) as compared to solution a)?
If you go with solution b), the only thing the MPI implementation needs to worry about is PREPAREing and RESTOREing the network state. All of the checkpoint specific issues and complexity such as queuing system integration, checkpoint file storage options like redundant local storage, etc.
Except that, as pointed out before, what PREPARE and RESTORE must do is very system and checkpoint mechanism dependent.
In case a), MPI implementations need to concern themselves with these issues AND support the non-standard checkpoint invocation API's for every different desired system checkpointer.
Agreed. The point of case a) is that we modify the MPI library knowing exactly what the checkpoint mechanism saves. Since we are handling the network specific parts, we can find workarounds for things like pinned pages, without too much impact on the network state (like having to completely close the network interface, to re-open it in RESTORE).
So that's a question of whether the responsibility for system-level checkpointer integration lays on the MPI implementor or the individual checkpoint implementors.
Going with b) gives MPI an opportunity to minimally specify an integration mechanism with system-level checkpointer's. If the MPI implementor does not wish to worry about these classes of CP/R systems, they just don't implement the minimal set of calls. If they do want the support, they implement the calls.
I agree that the point of case b) would be to relieve the data movement/saving/restoring part. However, one could argue that MPI is also well-placed to do this part (using MPI-IO for example). I am not convinced that this will give an opportunity to *minimally* specify the integration mechanism. This would be minimal in the number of calls to implement, but the cost of these calls would be nothing but optimal/minimal.
A single implementation of PREPARE and RESTORE would support most system-level checkpointers. For example our checkpointer that sits completely in user-land and BLCR that sits completely in the OS would have the same set of requirements. VMM level checkpointers have been suggested as being different. Wouldn't they either have the same requirements, or be completely transparent to the MPI stack i.e. snapshotting the OS, communication device, etc and allowing the protocol to sort out lost messages?
Moreover, to have an integration mechanism which support most system- level checkpointers, it seems to me that you imply that PREPARE/ RESTORE would be generic. Then, we need to define more precisely what they would do. The current proposition of Alexander is to have a vague definition (like PREPARE put the MPI in a checkpointable state, RESTORE restores communications, and MPI is authorized to do something that would not be checkpointable), and to let implementations find a way to implement this specification. We would end with implementation / checkpointing systems pairs, like Alexander said. So, I don't really see the benefit as compared to case a) (where we wold also have implementation / checkpointing systems pairs).
cheers, Joe
Cheers, Thomas
participants (1)
Thomas Herault
