Re: [Mpi3-ft] MPI_ANY_SOURCE ... again...
Hi Josh, all, I agree, I think the current approach is fine. Blocking is likely to be more problematic in many cases, IMHO. However, I am still a bit worried about splitting the semantics for P2P and Collective routines. I don't see a reason why a communicator after a collective call to validate wouldn't support ANY_SOURCE. If it is split, though, any intermediate layer trying to replace collectives with P2P solutions (and there are plenty of tuning frameworks out there that try exactly that) have a hard time maintaing the same semantics in an error case. Martin On Jan 25, 2012, at 3:06 PM, Howard Pritchard wrote:
Hi Josh,
Cray is okay with the semantics described in the current FTWG proposal attached to the ticket.
We plan to just leverage the out-of-band system fault detector software that currently kills jobs if a node goes down that the job was running on.
Howard
Josh Hursey wrote:
We really need to make a decision on semantics for MPI_ANY_SOURCE.
During the plenary session the MPI Forum had a problem with the current proposed semantics. The current proposal states (roughly) that MPI_ANY_SOURCE return when a failure emerges in the communicator. The MPI Forum read this as a strong requirement for -progress- (something the MPI standard tries to stay away from).
The alternative proposal is that a receive on MPI_ANY_SOURCE will block until completed with a message. This means that it will -not- return when a new failure has been encountered (even if the calling process is the only process left alive in the communicator). This does get around the concern about progress, but puts a large burden on the end user.
There are a couple good use cases for MPI_ANY_SOURCE (grumble, grumble) - Manager/Worker applications, and easy load balancing when multiple incoming messages are expected. This blocking behavior makes the use of MPI_ANY_SOURCE dangerous for fault tolerant applications, and opens up another opportunity for deadlock.
For applications that want to use MPI_ANY_SOURCE and be fault tolerant they will need to build their own failure detector on top of MPI using directed point-to-point messages. A basic implementation might post MPI_Irecv()'s to each worker process with an unused tag, then poll on Testany(). If any of these requests complete in error (MPI_ERR_PROC_FAIL_STOP) then the target has failed and the application can take action. This user-level failure detector can (should) be implemented in a third-party library since failure detectors can be difficult to implement in a scalable manner.
In reality, the MPI library or the runtime system that supports MPI will already be doing something similar. Even for MPI_ERRORS_ARE_FATAL on MPI_COMM_WORLD, the underlying system must detect the process failure, and terminate all other processes in MPI_COMM_WORLD. So this represents a -detection- of the failure, and a -notification- of the failure throughout the system (though the notification is an order to terminate). For MPI_ERRORS_RETURN, the MPI will use this detection/notification functionality to reason about the state of the message traffic in the system. So it seems silly to force the user to duplicate this (nontrivial) detection/notification functionality on top of MPI, just to avoid the progress discussion.
So that is a rough summary of the debate. If we are going to move forward, we need to make a decision on MPI_ANY_SOURCE. I would like to make such a decision before/during the next teleconf (Feb. 1).
I'm torn on this one, so I look forward to your comments.
-- Josh
-- Joshua Hursey Postdoctoral Research Associate Oak Ridge National Laboratory http://users.nccs.gov/~jjhursey
-- Howard Pritchard Software Engineering Cray, Inc. _______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
________________________________________________________________________ Martin Schulz, [email protected], http://people.llnl.gov/schulzm CASC @ Lawrence Livermore National Laboratory, Livermore, USA
participants (1)
Martin Schulz
