Re: [Mpi3-ft] Communicator Virtualization as a step forward
First, this API works only for the synch-and-stop protocol. It does not support any other protocol and this will lead into bad places in the future because this protocol scales poorly with increasing failure rates since it requires all processes to participate in every single recovery. I can discuss the reasons for my assertion in more detail if you'd like. Second, this API is not compatible with application-level checkpointing. An application-level checkpointer can deal with internal MPI state in one of two ways. One option is to checkpoint it at a high-level by using only the existing MPI calls, performing the appropriate tracking of messages at calls to MPI_Send and MPI_Recv. The simplest example of this is to ensure that there is no communication going on at the time of the checkpoint, and then save each process' state immediately after calling MPI_Barrier(). If this is the option used, there is no need for any API extensions. The second option is for the application to somehow same MPI internal data structures, which is what the MPI_Prepare_for_checkpoint call is for: to make sure that all MPI state is in locations accessible by the application. Where is that? Well, it depends on the operating system and the hardware. Does the application need to checkpoint and restore MPI's open file handles or shared memory regions or is MPI supposed to let those go during MPI_Prepare_for_checkpoint? The point is, all these details cannot be defined in the MPI spec and if this is the case, the call will not be sufficiently well-defined to be used by an application-level checkpointer. However, it can be used by the application to initiate a system-level checkpoint since in this case all those details will not be the application's problem. Finally, it does support system-initiated checkpointing. If the system wants to start a checkpoint in the middle of an MPI_Send() call, this API provides no help. If we care about this use-case we need to allow checkpoints to be taken at all times or provide a way to register a callback that tells the system when a checkpoint can next be taken. The bottom line given the above issues is that the only benefit this API does have is providing a common set of names for functions that have poor semantics and limited functionality. This benefit does not pass the bar. Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected] http://greg.bronevetsky.com At 09:27 AM 2/18/2009, Supalov, Alexander wrote:
I see. Let me explain what I think those two calls would do to facilitate checkpointing.
The program piece would look as follows:
CALL MPI_PREPARE_FOR_CHECKPOINT
! Whatever calls are necessary to do the actual checkpointing, including, in the case of resident monitoring checkpointer, none.
CALL MPI_RESTORE_AFTER_CHECKPOINT
The first call will bring MPI into a state that is acceptable to the checkpointer involved. This may include quiescence, etc.
Then the checkpointer will do its job. Note that this may be application level checkpointer that saves two important arrays. Or this may be a system checkpointer that dumps the memory, etc. Finally, this can be a checkpointer that is notified when the MPI_PREPARE_FOR_CHECKPOINT is about to leave and does the job in some way without the program calling it.
The second call will restore the MPI state to what it was, functionally, after the checkpoint. "Functionally" here means that this may include running on a different set of nodes, etc.
Is it this scenario that you think does not pass the bar? If so, in what way?
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Greg Bronevetsky Sent: Wednesday, February 18, 2009 6:20 PM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group; MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] Communicator Virtualization as a step forward
My point is that each MPI implementation will have to negotiate with each checkpointer what this call will mean on each platform, meaning that it is upto the implementation-specific call to do all that magic. It doesn't save the application any real effort to call this routine by its implementation-specific name rather than a unified name given that the other two major problems are not solved: - Providing a uniform way for checkpointers and MPI implementations to interact (THE major for having this proposal in the first place) and - Support for more than the synch-and-stop checkpointing protocol, which does scales poorly with rising failure rates.
My point here is that covering one of the three major issues is not good enough to modify the MPI specification and I don't think that we'll ever be able to do more than that. We're pretty much agreed in the working group that the first point above cannot be done and I don't think that the second can be done without providing callbacks to be called for each incoming/outgoing message.
Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected] http:// greg.bronevetsky.com
At 08:40 AM 2/18/2009, Supalov, Alexander wrote:
Thanks. How will the checkpointer-specific call talk to the MPI?
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Greg Bronevetsky Sent: Wednesday, February 18, 2009 5:29 PM To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group; MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Subject: Re: [Mpi3-ft] Communicator Virtualization as a step forward
Thanks. How will you let the MPI know the checkpoint is coming, to give it a fair chance to prepare to this and then recover after the checkpoint? This is akin to the MPI_Finalize/MPI_Init in some sense, midway thru the job, hence the analogy.
Just use the checkpointer-specific call. The call is going to have checkpointer-specific semantics, so why not give it a checkpointer-specific name? I understand that there is some use to allowing applications to use the same name across all checkpointers but the bar should be higher than that for adding something to the standard. Also, right now the whole approach inherently only supports one checkpointing protocol: synch-and-stop. If we can work out a more generic API that supports other protocols I think that it may have enough value to be included in the spec. Right now it still hasn't passed the bar.
_______________________________________________ mpi3-ft mailing list [email protected] http:// lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
Greg Bronevetsky
