Re: [Mpi3-ft] Ticket 323 - status?
Guess we can agree to disagree on your conclusions. It is true that there are non-HPC users that want to run past errors (my own org included), but that problem is relatively easier to solve than the overall MPI issue as it doesn't involve things like collectives. As for HPC, I'll note that the OMPI mailing list has nearly zero questions for even the current level of FT, and those that do come in are from students doing research (not production users). And yes, I know bigger clusters are in the works, but as I noted, there are other solutions being worked for them too. My point was solely that there are multiple ways of addressing the problem, and that making major alterations to MPI is only one of them - and possibly a less attractive approach to some of the alternatives. So it may well be that people would prefer to leave MPI alone for now, pending more research that reduces the risk and performance penalties. In that vein, I would suggest you consider releasing an "FT-MPI" again, or perhaps defining a quasi-standard set of MPI extensions that an implementation that wants to provide an FT version could support. The latter would still meet your desire to provide FT to a broader audience, but would avoid forcing ALL implementations to support something that their customers may not want. Let me re-emphasize: I'm not saying this was all for naught. I'm trying to suggest reasons why the body might resist adopting this proposal, and possible paths forward that would still support the work. Forcing a community to adopt FT as "standard" may not be the best way in the near term. Ralph On Wed, May 30, 2012 at 10:47 PM, Richard Graham <[email protected]>wrote:
Actually, this is a working group that went out and spent quite a bit of effort to collect user input. The issue is that it took a couple of years until someone had time to start an implementation, then took time for users to try it out and provide feedback, and then the broader forum started providing more input once text was actually written.****
It is true that this is important to HPC, however it is also true that there are quite a few users outside of the HPC community that would like to use MPI, but can’t because most/all MPI’s currently terminate on process failure. We had users from the HPC community attend for a while, users with enterprise needs, and we even had input from an online gaming company. Even as recently as a couple of weeks ago this same point was brought up by some at Mellanox, when this was not even the topic of discussion. This is far from just a research activity of interest to a small number of users.****
Rich****
*From:* [email protected] [mailto: [email protected]] *On Behalf Of *Ralph Castain *Sent:* Thursday, May 31, 2012 11:45 AM
*To:* MPI 3.0 Fault Tolerance and Dynamic Process Control working Group *Subject:* Re: [Mpi3-ft] Ticket 323 - status?****
Obviously, I can't speak for the folks who attended and voted "no", either directly or by abstaining. However, I have talked to at least a few people, and can offer a point or two about the concerns.
First, the last study I saw published on the subject of FT for MPI showed a very low level of interest in FT within the MPI community. It based this on a usage analysis that showed something over 90% of clusters being too small to see large failure rates. On the clusters that were large enough (primarily at the national labs, who pretty clearly voted no), over 80% of the MPI jobs lasted less than 1 hour.
So the size of the community that potentially benefits from FT is very small. In contrast, despite assurances it would be turned off unless specifically requested, it was clear from the proposals that FT would impact a significant fraction of the code, thus raising the potential for a substantial round of debugging and instability.
For that majority who would see little-to-no benefit, this isn't an attractive trade-off.
Second, those who possibly could benefit tend to take a more holistic view of FT. If you step back and look at the cluster as a system, then there are multiple ways of addressing the problems of failure during long runs. Yes, one way is to harden MPI to such events, but that is probably the hardest solution.
One easier way, and the one being largely touted at the moment, is to make checkpointing of an application be a relatively low-cost event so that it can be frequently done. This is being commercialized as we speak by the addition of SSDs to the usual parallel file system, thus making a checkpoint run at very fast speeds. In fact, "burst" buffers are allowing the checkpoint to dump very quickly, and then slowly drain to disk, rendering the checkpoint operation very low cost. Given that the commercial interests coincide with the HPC interests, this solution is likely to be available from cluster suppliers very soon at an attractive price.
Combined with measures to make restart very fast as well, this looks like an alternative that has no performance impact on the application at the MPI level, doesn't potentially destabilize the software, and may meet the majority of needs.
I'm not touting this approach over any other, mind you - just trying to point out that the research interests of the FT/MPI group needs to be considered in a separate light from the production interests of the community. What you may be experiencing (from my limited survey) is a reflection of that divergence.
Ralph
On Wed, May 30, 2012 at 6:55 PM, George Bosilca <[email protected]> wrote:****
On May 31, 2012, at 08:44 , Martin Schulz wrote:****
Several people who abstained had very similar concerns, but chose the abstain vote since they know it meant no, ****
Your interpretation is barely making a "simple majority" in the forum, as highlighted by parallel discussions in the other email threads. But let's leave this discussion in its own thread.****
But you're right, both "no" and "abstain" votes should be addressed. Bill made his point very clear, and to be honest he was the only one that raised a __valid__ point about the FT proposal. Personally, I am looking forward to fruitful discussions during our weekly phone-calls where the complaints raised during the voting will be brought forward in the way that the working group will have a real opportunity to address them as they deserve. In other terms we are all counting on you guys to enlighten us on the major issues with this proposal and the potential solutions you envision or promote.****
george.****
Hi George,****
One other no was Intel as far as I remember, but I don't remember the 5th. However, I would suggest not to focus on the no votes alone. Several people who abstained had very similar concerns, but chose the abstain vote since they know it meant no, but they agreed with the general necessity of FT for MPI. I remember, for example, Bill saying that for him abstain meant no, but that changes later on could change his mind. Based on this interpretation, the ticket definitely had more than 5 no votes.****
Martin****
On May 31, 2012, at 8:34 AM, Darius Buntinas wrote:****
Argonne was not convinced that we (FTWG) had the right solution, and the large changes in the text mentioned previously did not instill confidence. So it was decided that Argonne would vote against the ticket.
-d
On May 30, 2012, at 6:24 PM, George Bosilca wrote:
In total there were 5 no votes. I wonder who were the other two, they might be willing to enlighten us on their reasons to vote against.****
george.****
On May 31, 2012, at 05:48 , Anthony Skjellum wrote:****
Three no votes were LLNL, Argonne, and Sandia. Since MPI is heavily driven by DOE, convincing these folks would be important. ****
Tony Skjellum, [email protected] or [email protected]****
Cell 205-807-4968****
On May 31, 2012, at 5:10 AM, Richard Graham <[email protected]> wrote:****
The main objection raised is that the text has still been having large changes, and if not for the pressure of the 3.0 deadline, this would not have come up for a vote. I talked one-on-one with many that either voted against or abstained, and this was the major (not only) point raised.****
Rich****
-----Original Message-----****
From: [email protected] [mailto: [email protected]] On Behalf Of Aurélien Bouteiller****
Sent: Wednesday, May 30, 2012 10:05 PM****
To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group** **
Subject: Re: [Mpi3-ft] Ticket 323 - status?****
It seems we had very little, if any, technical opposition on the content of the proposal itself, but mostly comments on the process. I think we need to understand more what are the oppositions. Do we have a list of who voted for and against and their rationale?****
Aurelien****
Le 30 mai 2012 à 08:52, Josh Hursey a écrit :****
That is unfortunate. A close vote (7 yes to 9 no/abstain). :/****
Thanks,****
Josh****
On Wed, May 30, 2012 at 8:38 AM, Thomas Herault ****
Le 30 mai 2012 a 01:44, George Bosilca a écrit:****
The ticket has been voted down. Come back in 6 months, maybe 3.1. The votes were 7 yes, 4 abstains and 5 no.****
Thomas****
Le 30 mai 2012 à 07:02, Josh Hursey a écrit :****
How did the vote go for the fault tolerance ticket 323?****
-- Josh****
Joshua Hursey****
Postdoctoral Research Associate****
Oak Ridge National Laboratory****
http://users.nccs.gov/~jjhursey****
_______________________________________________****
mpi3-ft mailing list****
http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft****
Joshua Hursey****
* Dr. Aurélien Bouteiller****
* Researcher at Innovative Computing Laboratory****
* University of Tennessee****
* 1122 Volunteer Boulevard, suite 350****
* Knoxville, TN 37996****
* 865 974 9375****
_______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft****
________________________________________________________________________ Martin Schulz, [email protected], http://people.llnl.gov/schulzm CASC @ Lawrence Livermore National Laboratory, Livermore, USA****
participants (1)
Ralph Castain
