[Mpi3-ft] MPI_ANY_SOURCE ... again...
We really need to make a decision on semantics for MPI_ANY_SOURCE. During the plenary session the MPI Forum had a problem with the current proposed semantics. The current proposal states (roughly) that MPI_ANY_SOURCE return when a failure emerges in the communicator. The MPI Forum read this as a strong requirement for -progress- (something the MPI standard tries to stay away from). The alternative proposal is that a receive on MPI_ANY_SOURCE will block until completed with a message. This means that it will -not- return when a new failure has been encountered (even if the calling process is the only process left alive in the communicator). This does get around the concern about progress, but puts a large burden on the end user. There are a couple good use cases for MPI_ANY_SOURCE (grumble, grumble) - Manager/Worker applications, and easy load balancing when multiple incoming messages are expected. This blocking behavior makes the use of MPI_ANY_SOURCE dangerous for fault tolerant applications, and opens up another opportunity for deadlock. For applications that want to use MPI_ANY_SOURCE and be fault tolerant they will need to build their own failure detector on top of MPI using directed point-to-point messages. A basic implementation might post MPI_Irecv()'s to each worker process with an unused tag, then poll on Testany(). If any of these requests complete in error (MPI_ERR_PROC_FAIL_STOP) then the target has failed and the application can take action. This user-level failure detector can (should) be implemented in a third-party library since failure detectors can be difficult to implement in a scalable manner. In reality, the MPI library or the runtime system that supports MPI will already be doing something similar. Even for MPI_ERRORS_ARE_FATAL on MPI_COMM_WORLD, the underlying system must detect the process failure, and terminate all other processes in MPI_COMM_WORLD. So this represents a -detection- of the failure, and a -notification- of the failure throughout the system (though the notification is an order to terminate). For MPI_ERRORS_RETURN, the MPI will use this detection/notification functionality to reason about the state of the message traffic in the system. So it seems silly to force the user to duplicate this (nontrivial) detection/notification functionality on top of MPI, just to avoid the progress discussion. So that is a rough summary of the debate. If we are going to move forward, we need to make a decision on MPI_ANY_SOURCE. I would like to make such a decision before/during the next teleconf (Feb. 1). I'm torn on this one, so I look forward to your comments. -- Josh -- Joshua Hursey Postdoctoral Research Associate Oak Ridge National Laboratory http://users.nccs.gov/~jjhursey
participants (1)
Josh Hursey
