Re: [Mpi3-ft] Communicator Virtualization as a step forward
I don't necessarily agree with the statement that FT-MPI is a subset of the current spec. As the current spec can be implemented on top of FT-MPI (with help from the PMPI interface), this tend to prove the opposite. However, I agree there are several features in the current spec that were not covered by the FT-MPI spec, but these features can be implemented on top of FT-MPI. As far as I understood, this is what Josh proposed, as this will give a quick start (i.e. FT-MPI implementation is already available). george. On Feb 12, 2009, at 14:01 , Graham, Richard L. wrote:
Josh, Very early on in the process we got feedback from users that an ft- mpi like interface was of no interest to them. They would just as soon terminate the application and restart rather than use this sort of approach. Having said that, there is already previous demonstration that the ft-mpi approach is useful for some applications. If you look closely at the spec, the ft-mpi approach is a subset. of the current subset. I am working on pulling out the api's and expanding the explanations. The goal is to have this out before the next telecon in two weeks. Prototyping is under way, with ut, cray, and ornl committed to working on this. Right now supporting infrastructure is being developed. Your point on the mpi 2 interfaces is good. A couple of people had started to look at this when it looked like this might make it into the 2.2 version. The changes seemed to be more extensive than expected, so work stopped. This does need to be picked up on.
Rich ------Original Message------ From: Josh Hursey To: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group ReplyTo: MPI 3.0 Fault Tolerance and Dynamic Process Control working Group Sent: Feb 12, 2009 8:31 AM Subject: Re: [Mpi3-ft] Communicator Virtualization as a step forward
It is a good point that local communicator reconstruction operations require a fundamental change in the way communicators are handled by MPI. With that in mind it would probably take as much effort (if not more) to implement a virtualized version on top of MPI. So maybe it will not help as much as I had originally thought. Outside of the paper, do we have the interface and semantics of these operations described anywhere? I think that would help in trying to keep pace with the use cases.
The spirit of the suggestion was as a way to separate what (I think) we can agree on as a first step (FT-MPI-like model) from the communicator reconstruction, which I see as a secondary step. If we stop to write up what the FT-MPI-like model should look like in the standard, then I think we can push forward on other fronts (prototyping of step 1, standardization of step 1, application implementations using step 1) while still trying to figure out how communication reconstruction should be expressed in the standard such that it is usable in target applications.
So my motion is that the group explicitly focus effort on writing a document describing the FT-MPI-like model we consider as a foundation. Do so in the MPI standard language, and present it to the MPI Forum for a straw vote in the next couple of meetings. From this document we can continue evolving it to support more advanced features, like communicator reconstruction.
I am willing to put effort into making such a document. However, I would like explicit support from the working group in pursing such an effort, and the help of anyone interested in helping write-up/define this specification.
So what do people think taking this first step?
-- Josh
On Feb 11, 2009, at 5:57 PM, Greg Bronevetsky wrote:
I don't understand what you mean by "We can continue to pursue communicator reconstruction interfaces though a virtualization later above MPI." To me it seems that such interfaces will effectively need to implement communicators on top of MPI in order be operational, which will take about as much effort as implementing them inside MPI. In particular, I don't see a way to recreate a communicator using the MPI interface without making collective calls. However, we're defining MPI_Rejoin (or whatever its called) to be a local operation. This means that we cannot use the MPI communicators interface and must instead implement our own communicators.
The bottom line is that it does make sense to start implementing support for the FT-MPI model and evolve that to a more elaborate model. However, I don't think that working on the rest above MPI will save us any effort or time.
Greg Bronevetsky Post-Doctoral Researcher 1028 Building 451 Lawrence Livermore National Lab (925) 424-5756 [email protected]
At 01:17 PM 2/11/2009, Josh Hursey wrote:
In our meeting yesterday, I was sitting in the back trying to take in the complexity of communicator recreation. It seems that much of the confusion at the moment is that we (at least I) are still not exactly sure how the interface should be defined and implemented.
I think of the process fault tolerance specification as a series of steps that can be individually specified building upon each step while working towards a specific goal set. From this I was asking myself, is there any foundational concepts that we can define now so that folks can start implementation.
That being said I suggest that we consider FT-MPI's model of all communicators except the base 3 (COMM_WORLD, COMM_SELF, COMM_NULL) are destroyed on a failure as the starting point for implementation. This would get us started. We can continue to pursue communicator reconstruction interfaces though a virtualization later above MPI. We can use this layer to experiment with the communicator recreation mechanisms in conjunction with applications while pursing the first step implementation. Once we start to agree on the interface for communicator reconstruction, then we can start to push it into the MPI standard/library for a better standard/implementation.
The communicator virtualization library is a staging area for these interface ideas that we seem to be struggling with. The virtualization
------Original Message Truncated------
_______________________________________________ mpi3-ft mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-ft
participants (1)
George Bosilca
